Dominator flat spot**UPDATE** #675718
04/20/10 02:15 PM
04/20/10 02:15 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
I have had some serious carb issues lately, yesterday with the help of Mr.Pbody and DC426, I was able to get it running much better. I made some whole sale changes and fattened the heck out of it. I test drove it, and all seemed pretty good, a little lazy, but the original problem of the flat spot was just about nil. Take it out this morning to have DC help with some fine tuning and it's much better, not nearly as rich as it was, and it's much more crisp and responsive.
The run down of what we did is:
Lowered the fuel pressure from 7.75 to 7 psi.
lowered the primary jetting down to 84 primary and 92 in the secondary. With a 3.5 PV.
Synchronized the idle mixture screws. (I had them all jacked up).
Lowered the idle about 100 RPM, it now idles at about 1050 in neutral and 950 in gear.
It was still just a tad lazy on the rev, so we adjust the pump arm and tried a 42 squirter, for whatever reason, it didnt like that; changed the idle characteristics, so we went back to the 35.
So now it's about as crisp as it ever was, very good idle quality in and out of gear, but the flat spot has shown up again. Not really bad but I had to feather the throttle just a touch to get through it. The ONLY time it has it is when loaded in high gear. I only notice it if I'm cruising and have to get out of the throttle for a car in front of me, then roll back into it. When it does that I can roll back out of the throttle and give it a little pump shot and all is fine. Like I said all characteristics are good, idle, cruise and WOT, just that little hesitation or flat spot. If I could just figure that out I'd be a happy camper. Just fishing here to see if anybody had some ideas.
Thanks,
John
Re: Dominator flat spot [Re: PS Arrow] #675719
04/20/10 02:26 PM
04/20/10 02:26 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
What number my 9375 only likes 25 to 28 squirters??
Re: Dominator flat spot [Re: Dodgem] #675720
04/20/10 02:29 PM
04/20/10 02:29 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
It is a QFT 1050
Re: Dominator flat spot [Re: PS Arrow] #675721
04/20/10 03:34 PM
04/20/10 03:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It is a QFT 1050
Whats the time and does it have advance (base and total)
Re: Dominator flat spot [Re: MR_P_BODY] #675722
04/20/10 03:39 PM
04/20/10 03:39 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Timing is at 38 and is locked.
Re: Dominator flat spot [Re: PS Arrow] #675723
04/20/10 04:02 PM
04/20/10 04:02 PM
Q
Quicktree Offline
Quicktree  Offline
Q
have you tried bigger squirters? don't see the advantage of lowering the fuel pressure. that maybe ok at low rpm but I bet you run out of fuel on the big end. just went through that. took 9.5 pounds of fuel pressure to run all the way through the 1/4 without running out of fuel.
Re: Dominator flat spot [Re: Quicktree] #675724
04/20/10 04:10 PM
04/20/10 04:10 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
We'll have to wait and see on the fuel pressure Tony, but thats good food for thought. We did try a bigger squirter, but not on a test drive, we tried a 42 and for whatever reason it acted funny just sitting there so we went back to the original.
Re: Dominator flat spot [Re: Quicktree] #675725
04/20/10 04:11 PM
04/20/10 04:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To be honest Tony 9.5 will blow the needle off the
seat but YOUR gauge might say 9.5 but with a accurate
gauge it WILL be lower, more like 8.5 max
Re: Dominator flat spot [Re: MR_P_BODY] #675726
04/20/10 04:16 PM
04/20/10 04:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
it runs fine at 9.5, I put 2 different guages on and checked it. no problem with the needle and seat. anything less and it ran out of fuel at the mph marker. I slowly increased it from 7.5 to 9.5. everytime the car got better.
Re: Dominator flat spot [Re: PS Arrow] #675727
04/20/10 04:17 PM
04/20/10 04:17 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
I'm not sweating it like I was before when I just could not get the thing to run well at all. I may be asking too much, the flat spot is not affecting the range of operation, the cruise is nice, accelerates in stop and go driving just fine and wide open is great (for short duration). I could actually live with it as is, just thought I throw it out there if anybody had some ideas. I can say this is the best it has ever been, I used to fight the flat spot while in cruise, so I know it's better.
Re: Dominator flat spot [Re: PS Arrow] #675728
04/20/10 04:26 PM
04/20/10 04:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does it start to squirt AS SOON as you touch into
the throttle ... might need to adjust WHEN the pump
shot comes in
Re: Dominator flat spot [Re: MR_P_BODY] #675729
04/20/10 04:31 PM
04/20/10 04:31 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Thats a thought Mike, I know we adjusted it, I may have had too much slack in it and DC tightened it up, I'll take another look at it.
Re: Dominator flat spot [Re: PS Arrow] #675730
04/20/10 04:43 PM
04/20/10 04:43 PM
Have you adjusted both accelerator pump arms so there is no freeplay between the pump arm and the pump lever? Most of the Holley carbs I've seen have slop bewteen the pump arm amd the lever Holley tech says to adjust the screw on the pump lever so it has .015 or a little more travel(clearance between the lever and the bottom of the screw with a feeler gauge) when at WOT. That ends up putting tension on the adjuster so it pumps immieditily (SP?) whenever the throttle is moved
Re: Dominator flat spot [Re: Cab_Burge] #675731
04/20/10 05:36 PM
04/20/10 05:36 PM
UK
602heavy Offline
602heavy  Offline
UK
If the pump arms are set correctly i would be looking @ mixture screws , a slight bog @ tip in coming back on the throttle is a lean spot between idle/transition , turn all four mixture screws out 1/4 turn & go try it.
Re: Dominator flat spot [Re: 602heavy] #675732
04/20/10 06:11 PM
04/20/10 06:11 PM
PA
moparacer Offline
moparacer  Offline
PA
What size Idle air bleeds does it have in it?
I had to change the idle fuel restrictions, idle air bleeds and transfer slot jets around in mine untill I got it to work right at part throttle and in transition.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Dominator flat spot [Re: moparacer] #675733
04/20/10 06:26 PM
04/20/10 06:26 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If it's a 3 circut carb richen the intermediate air bleed.
Re: Dominator flat spot [Re: B G Racing] #675734
04/20/10 06:32 PM
04/20/10 06:32 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
Bob, I think it's still an idle circuit issue. The problem arises when he cruising and lets off the throttle. Then steps back on the throttle and it hesitates. John hasn't said but I don't think it's doing it from a stop. It also didn't do it before we made adjustments earlier today. I think it's just an air screw adjustment.
DC
Re: Dominator flat spot [Re: dc426] #675735
04/20/10 06:35 PM
04/20/10 06:35 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Re: Dominator flat spot [Re: B G Racing] #675736
04/20/10 07:16 PM
04/20/10 07:16 PM
PA
moparacer Offline
moparacer  Offline
PA
If its a 3 circuit block the 3rd circuit off, or convert it to a 2 circuit I.M.O. lol
I pulled whats left of my hair out with my 3 circuit last year until I converted it to a 2 circuit.
No problems since....
Re: Dominator flat spot [Re: dc426] #675737
04/20/10 07:43 PM
04/20/10 07:43 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
DC
Nope not doing it from a stop....
