Vibration turning steering wheel to left on hi way. #674702
04/19/10 12:15 PM
04/19/10 12:15 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
Hello all.I have a 72 duster.Was slant six now 318.I used schmacher mounts when v8 put in.When i am on the highway and turn wheel to left I hear a noise or vibration.Turn to right noise/vibration goes away.I been chaseing this for about a year.Anybody got any advice.727 Trans 8 3/4 rear end.
Re: Vibration turning steering wheel to left on hi way. [Re: Crabra] #674703
04/19/10 01:01 PM
04/19/10 01:01 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Check your wheel bearings.
Re: Vibration turning steering wheel to left on hi way. [Re: Crabra] #674704
04/19/10 01:07 PM
04/19/10 01:07 PM
Texas
70Runnerdude Offline
Texas
When you turn to the left you are putting more of a load to the right side so I would check the right side for the wheel bearings ,wheel lug nuts, bad tire, or something in the brake area.
Re: Vibration turning steering wheel to left on hi way. [Re: Crabra] #674705
04/19/10 01:08 PM
04/19/10 01:08 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Do you have power steering?
Re: Vibration turning steering wheel to left on hi way. [Re: Snoopy] #674706
04/19/10 04:59 PM
04/19/10 04:59 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
Yes I have power strg.
Thanks to all who replied.Really thank you
Re: Vibration turning steering wheel to left on hi way. [Re: Crabra] #674707
04/19/10 07:12 PM
04/19/10 07:12 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
Re: Vibration turning steering wheel to left on hi way. [Re: 70Runnerdude] #674708
04/19/10 11:23 PM
04/19/10 11:23 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
When you turn to the left you are putting more of a load to the right side so I would check the right side for the wheel bearings, . . . I would check the left also, but probably a bad bearing on the right.
DRIVE EM, DONT HIDE EM.
Re: Vibration turning steering wheel to left on hi way. [Re: ledft79] #674709
05/01/10 11:56 AM
05/01/10 11:56 AM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
Okay ladies and germs.I checked the wheel brg's and adjuusted the front calipers.Still have my noise.I think ctr link is rubbing oil pan when I switch from right lane to left lane on highway.How do I raise the engine on the drivers side.Any body done this,any pictures.
