Cracked Torque converter
#674456
04/19/10 09:05 AM
04/19/10 09:05 AM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
Had my car int he shop for what I thought was a leaky front seal. After pulling the trans apart and replacing some glazed 3rd gear clutches (another post). The leak was still there, they are now thinking the torque converter is cracked. Has this ever happened to anyone? This is in a 67 coronet, 550hp 383, supercharged efi. 4000#lb car. The converter is a 9.5" PTC unit.
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
Re: Cracked Torque converter
[Re: Mr340]
#674458
04/19/10 09:32 AM
04/19/10 09:32 AM
Posts: 1,290 New Kent, Va.
bobbyb
New Kent, Va.
Just had mine fixed last week for a front seal leak and it turned out to be a cracked torque converter. Its just a 904 behind a 318 2 bbl. not sure of the manufacture of the converter. Had it rebuilt about 10 years ago with about 10,000mi. on it.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
[Re: 727builder]
#674460
04/19/10 10:58 AM
04/19/10 10:58 AM
whiplash
Summit, NJ
how do you pressure test them? Why is it a common failulre?
[Re: whiplash]
#674461
04/19/10 12:28 PM
04/19/10 12:28 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Might be a clearance issue.
[Re: whiplash]
#674462
04/19/10 12:55 PM
04/19/10 12:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Get a hose that fits over the hub and use air pressure then use soapy water around the out side
[Re: BobR]
#674463
04/19/10 01:30 PM
04/19/10 01:30 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
I think mine failed becuase I had the flex plate bolts loosened and three of the four ears of the flex plate broke. I was at the track and heard a tapping noise at Idle that went away as i raised the rpm's. I tighted the bolts (didn't notice the cracks at first) and drove it home. the noise came back in a couple of days so I took a better look and realized the flex plate had cracked. In the mean time it developed what I thouhgt was a front seal leak but was actually a cracked hub. This was in a 727 behind a warmed over 340 with 4.30 gears pushing about 3800lbs.
