oil pickup to pan clearance #674185
04/18/10 10:04 PM
04/18/10 10:04 PM
Saskatchewan, Canada
barracudabob Offline OP
On an RB emgine, what's the optuimum oil pickup to pan clearance, and whats the best way to measure it? Thanks in advance, Bob
Re: oil pickup to pan clearance [Re: barracudabob] #674186
04/18/10 10:08 PM
04/18/10 10:08 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Set it up for zero clearance with the bare pan, then when you add gaskets/windage tray it'll be perfect.
Re: oil pickup to pan clearance [Re: Bill MeLater] #674187
04/18/10 10:32 PM
04/18/10 10:32 PM
IN
ahy Offline
ahy  Offline
IN
It depends on pickup type... the MOPAR style pickup is designed for zero clearance. Most aftermarket pickups need clearance.
Re: oil pickup to pan clearance [Re: ahy] #674188
04/18/10 10:51 PM
04/18/10 10:51 PM
The Mopar service manuals call for zero clearnces on the stock pickups, I use a coat hangar and set the pickup so the coat hanger (stuck through the oil pan drain plugs on the stock type pans ) barely slides under the low side of the stock pickups On the non stock pickups use the manufacturers specs.
