5/16 or 3/8 Fuel Line? #67401
06/04/08 12:29 PM
06/04/08 12:29 PM
Massachusetts
LYNCHROAD69.5 Offline OP
Massachusetts
Replacing all my fuel lines and wanted some feedback on fuel line diameter. I believe original lines on my A12 car are 5/16". Should I replace with same or go to 3/8"? Any feedback would be appreciated.
Re: 5/16 or 3/8 Fuel Line? [Re: LYNCHROAD69.5] #67402
06/04/08 01:02 PM
06/04/08 01:02 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Yes, the original A12 lines are 5/16". If you look at any of the guys running the Muscle Car Drag Races, they all have 3/8" for the performance.
Re: 5/16 or 3/8 Fuel Line? [Re: Dave Watt] #67403
06/04/08 01:19 PM
06/04/08 01:19 PM
Massachusetts
Massachusetts
Dave, any opinion on if I should go to 3/8 or not?
Re: 5/16 or 3/8 Fuel Line? [Re: LYNCHROAD69.5] #67404
06/04/08 01:32 PM
06/04/08 01:32 PM
God's Country - Etowah, TN.
A34 Offline
A34  Offline
3/8" for performance, unless you're doing a super OE level resto.
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: 5/16 or 3/8 Fuel Line? [Re: A34] #67405
06/04/08 02:20 PM
06/04/08 02:20 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Re: 5/16 or 3/8 Fuel Line? [Re: Dave Watt] #67406
06/04/08 07:55 PM
06/04/08 07:55 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
The 5/16" line will be fine.
Re: 5/16 or 3/8 Fuel Line? [Re: Michael] #67407
06/04/08 08:20 PM
06/04/08 08:20 PM
for a stock car keep it 5/16", you'll have to change your sending unit also if you go with 3/8" line. you wont need 3/8" for stock application.
Re: 5/16 or 3/8 Fuel Line? #67408
06/04/08 09:37 PM
06/04/08 09:37 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The stock sending unit has a 3/8" outlet. If you go with the Hemi 3/8" fuel line to the fuel pump and then 5/16" from the fuel pump up to the vapor separator, nobody will notice or it wouldn't matter if they did. In fact, I thought I heard the 70 sixpack's were upgraded to the 3/8" fuel line and have a 3/8" inlet in the fuel pump? On the other hand, the 5/16" always worked fine for me on my A12.
