Tranny pan wouldn't stop leaking..... #673683
04/18/10 12:07 PM
04/18/10 12:07 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
I have a big block 727 with a B&M aluminum 4 quart more than stock pan part #10280.
I can't get the pan from stop leaking. It only leaks from the front side of the trans pan aka closest to the bellhousing.
I've done just a rubber gasket no RTV sealer.
Two rubber gaskets with no RTV sealer.
Rubber gasket with a good amount of RTV sealer. And it still leaked.
I then used a rubber gasket with a medium amount of RTV sealer hand tightened the bolts and tightened after an hour. It is still leaking. I made sure the bolts are tight, tightened a little more and its still leaking.
The top of the pan where it meets the bottom of the trans is completely flat. The stock pans have the little ridges on the top of the pans.
Anyone have problems with aftermarket pans not sealing ?
Re: Tranny pan wouldn't stop leaking..... [Re: 440727] #673684
04/18/10 12:13 PM
04/18/10 12:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why not go to the dealer and get the new style sandwich gasket and install it with no sealant? I have never had one leak and they are reusable a number of times.
Re: Tranny pan wouldn't stop leaking..... [Re: stumpy] #673685
04/18/10 12:20 PM
04/18/10 12:20 PM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
Is it the pan leaking or the vent behind the torque converter? If oil is coming out of the vent it will look like the front of the pan is leaking.
Re: Tranny pan wouldn't stop leaking..... [Re: 440727] #673686
04/18/10 12:50 PM
04/18/10 12:50 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Another vote for over full and coming out the front vent.
First it says
"727 Deep pan provides an additional 2-4 quart capacity, significantly improving the cooling ability of the fluid."
Usually 2 more is more like it and if you put a higher stall they hold less. when car sits torque drains back and makes it real high and leaks out vent and down front of tranny right to the pan.
Re: Tranny pan wouldn't stop leaking..... [Re: Dodgem] #673687
04/18/10 01:48 PM
04/18/10 01:48 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
linkage seal?
in my experiendce my tranny leaks allways seemed to come from pan gasket, and never were from there... allway linkage seal and rear band pivot seal.
Re: Tranny pan wouldn't stop leaking..... [Re: NachoRT74] #673688
04/18/10 02:00 PM
04/18/10 02:00 PM
Andrewh Offline
Andrewh  Offline
I agree. All my "pan" leaks were higher. Feel around or clean it all off and wait for drips. Then touch a paper towel up above the pan.
Re: Tranny pan wouldn't stop leaking..... [Re: Andrewh] #673689
04/18/10 02:29 PM
04/18/10 02:29 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Yep...at this point its not likely to be the pan.
Maybe the selector shaft seal?
Re: Tranny pan wouldn't stop leaking..... [Re: 440727] #673690
04/18/10 02:30 PM
04/18/10 02:30 PM
Virginia
BSharp Offline
BSharp  Offline
Virginia
If it really is a pan gasket leak, make sure one or more bolts aren't bottoming in their holes.
Re: Tranny pan wouldn't stop leaking..... [Re: Andrewh] #673691
04/18/10 02:45 PM
04/18/10 02:45 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Tranny pan wouldn't stop leaking..... [Re: Dodgem] #673692
04/18/10 02:54 PM
04/18/10 02:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
First it says
Its impossible to come out the vent when sitting. It would take several gallons to even get it close to the shaft centerline let alone the vent hole.
Leak is most likely dipstick or shift shaft seal,
Re: Tranny pan wouldn't stop leaking..... [Re: NITROUSN] #673693
04/18/10 05:18 PM
04/18/10 05:18 PM
scratchnfotraction Offline
clean and dry with brake clean
throw a hand full of baby powder on the area in ?
the powder will show you the leak way before it spreds to look like it else where
I would deff use one of the new gaskets with the alum pan
Re: Tranny pan wouldn't stop leaking..... [Re: scratchnfotraction] #673694
04/18/10 05:24 PM
04/18/10 05:24 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I have a deep chome pan. Used the Mopar rubber gasket and not a drop on the floor. No sealer. There the best gaskets
Re: Tranny pan wouldn't stop leaking..... [Re: scratchnfotraction] #673695
04/18/10 05:30 PM
04/18/10 05:30 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
x 2 on that baby-powder. But I don't agree at-all with the need to use any trick gaskets on a cast alum pan. Since LOTS of the sealing issues can be traced to bent pan-rails ... using a cast pan eliminates that problem.
Check ALSO the rubber seal for the throttle pressure linkage IN the VB near the shifter-seal in the case.
Re: Tranny pan wouldn't stop leaking..... [Re: dOOc] #673696
04/18/10 06:00 PM
04/18/10 06:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What's so trick about an updated factory gasket that is reusable?
Re: Tranny pan wouldn't stop leaking..... [Re: stumpy] #673697
04/18/10 06:08 PM
04/18/10 06:08 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
....because IMO .. it is not needed. What is the current cost diff ... cork and this one that you refer to ?
Re: Tranny pan wouldn't stop leaking..... [Re: dOOc] #673698
04/18/10 06:12 PM
04/18/10 06:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
$0 because you get to use it over and over again instead of the one time cheap gaskets that do have a tendency to leak. That and you can't overtorque it.
Re: Tranny pan wouldn't stop leaking..... [Re: stumpy] #673699
04/18/10 06:15 PM
04/18/10 06:15 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
I have a cork one on my 62 since the late 70's ... R&Red the pan many times .. no leaks.
Again ... WHAT is the cost diff ?
Re: Tranny pan wouldn't stop leaking..... [Re: dOOc] #673700
04/18/10 06:17 PM
04/18/10 06:17 PM
does not matter on the cost..we are high tech with it,and keeping up with the trendy stuff
Re: Tranny pan wouldn't stop leaking..... [Re: stumpy] #673701
04/18/10 06:18 PM
04/18/10 06:18 PM
Dougsmopars Offline
Dougsmopars  Offline
We now have disc brakes. Because there better. Things do improve with time. The new factory pan gasket is 100 times better then the cheap cork they used 40 years ago. Tell me do you still use a rotory phone?
Re: Tranny pan wouldn't stop leaking..... [Re: dOOc] #673702
04/18/10 06:23 PM
04/18/10 06:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Doc, I really don't believe that. I"ve been in this businness over 40 years and know better. Unless you are using a lot of rtv, which would be doing the gaskets job, that gasket would be too dried out and thin to hold any fluid back.
