Crank Shafts #673512
04/18/10 09:55 AM
04/18/10 09:55 AM
laurens,south carolina
mopar_rr Offline OP
mopar_rr  Offline OP
I AM NOT A SAMLL BLOCK PERSON ALWAYS HAD BIG BLOCKS.I WAS WONDERING WHAT AND IF POSSIALE IF A STEEL 318 CRANK WILL WORK IN A STELL CRANK 340.WHAT WOULD HAVE TO BE DONE TO MAKE IT WORK OR NOT..
HAVE A NICE MOPARIN DAY....
Re: Crank Shafts [Re: mopar_rr] #673513
04/18/10 10:20 AM
04/18/10 10:20 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Get it balanced and it should be fine.
Re: Crank Shafts [Re: buildanother] #673514
04/18/10 10:37 AM
04/18/10 10:37 AM
correct. Check clearances/straightness/magnaflux if need be
Re: Crank Shafts [Re: mopar_rr] #673515
04/19/10 09:29 PM
04/19/10 09:29 PM
NE MISSOURI
P
Purpleracer Offline
Purpleracer  Offline
P
NE MISSOURI
I heard that the 1967 318 had a steel crank?
Re: Crank Shafts [Re: Purpleracer] #673516
04/20/10 03:32 AM
04/20/10 03:32 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 318 went to cast cranks in the early 1970s. They were still internally balanced though.
As stated before, 273/318/340 cranks will interchange PHYSICALLY. You can have the 273/318 balanced to match 340 specs for under $200 at most machine shops.
