Oil pressure drop #673480
04/18/10 08:37 AM
04/18/10 08:37 AM
NE MISSOURI
P
Purpleracer Offline OP
P
NE MISSOURI
Has anyone else experienced oil pressure drop when engine is warm with roller bearing rockers and Indy SR heads?
Re: Oil pressure drop [Re: Purpleracer] #673481
04/18/10 09:20 AM
04/18/10 09:20 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
how much of a drop and under what conditions ?
Re: Oil pressure drop [Re: terzmo] #673482
04/18/10 10:28 AM
04/18/10 10:28 AM
NE MISSOURI
P
P
NE MISSOURI
It drops to about 30 PSI at 1200 RPM and goes back to 55 psi under acceleration. It use to run a range between 55 to 65 with iron heads and Crane adjustable rockers.
Re: Oil pressure drop [Re: Purpleracer] #673483
04/18/10 12:53 PM
04/18/10 12:53 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea the sr's really let a lot of oil in restricted it at the fittings in the back of the head to .050 or so.
