Page 2 of 3 1 2 3
Re: SS SPRING CARS. [Re: dustergirl340] #673237
04/19/10 07:24 AM
04/19/10 07:24 AM
Super Scamp Offline
Super Scamp  Offline
Old Scamp when it was inboard with SS springs and snubber..
Just One Man's Opinion Mopar Mafia Racing
Re: SS SPRING CARS. [Re: Super Scamp] #673238
04/19/10 07:49 AM
04/19/10 07:49 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Heres a pic of my sons car in the final at Bunker Hill Dragstrip saturday.We put SS springs on and made a new hole higher than the original to keep the rearend from being way up.Unfortunately he lost in the final on a breakout hogging up to much stripe on this pass.(His screen name on here is stripehog so i guess he lived up to it well)
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: SS SPRING CARS. [Re: moparmxz] #673239
04/19/10 03:05 PM
04/19/10 03:05 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
My old rule of thumb for SS spring ride height.... They were designed so that an imaginary line extended along the bottom of the rocker panel passes through the center line of the axle. Check out all the pics posted and you will see that unless you change the front mount height and/or use lowering blocks the rule still holds true after all these years. It looks too high with short tires. They were designed back in the 60's to use with 29.5" tall race tires. If you use short tires and/or want your car down in the weeds then they are the wrong springs for you. I built a few cars with SS springs back in the day but my current car has had Caltracks and monoleafs on it for years. I'll never buy another set of SS springs. Never.
Re: SS SPRING CARS. [Re: GomangoCuda] #673240
04/19/10 05:55 PM
04/19/10 05:55 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Right now,I have 28"x11.5" QTP's but I may go up to 29". My dad had 28"x12" slicks oh his duster and ran SS springs. IF I had the money,I would go Cal-tracs but $700.00-$900.00 vs. $220??? Its a clear picture for me.
Re: SS SPRING CARS. [Re: MIKES_DUSTER] #673241
04/19/10 11:45 PM
04/19/10 11:45 PM
Any more input??
Re: SS SPRING CARS. [Re: MIKES_DUSTER] #673242
04/19/10 11:45 PM
04/19/10 11:45 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
SS springs rear shackle mounted through the frame
springs moved 3" inboard
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: SS SPRING CARS. [Re: DragDart360] #673243
04/20/10 12:20 AM
04/20/10 12:20 AM
How tall and wide are your tires???
Re: SS SPRING CARS. [Re: moparmxz] #673244
04/20/10 01:35 AM
04/20/10 01:35 AM
organ
maximum entropy Offline
organ
ss springs in a nova- that's just cool!
Re: SS SPRING CARS. [Re: maximum entropy] #673245
04/20/10 07:22 AM
04/20/10 07:22 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
His car is the silver GTS Dart.lol
Re: SS SPRING CARS. [Re: MIKES_DUSTER] #673246
04/20/10 07:47 AM
04/20/10 07:47 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
29x10x15 on 6.5' backspace stock axle length
Re: SS SPRING CARS. [Re: DragDart360] #673247
04/20/10 08:37 AM
04/20/10 08:37 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Here's mine with the springs relocated into the frame. Took the front mounts and used them for the rear shackle mount welded to the bottom of the rear frame rail. 29.5x11.5 tire
Re: SS SPRING CARS. [Re: roadhazard] #673248
04/20/10 10:35 AM
04/20/10 10:35 AM
Any pictures of that???
Re: SS SPRING CARS. [Re: MIKES_DUSTER] #673249
04/20/10 10:37 AM
04/20/10 10:37 AM
I guess the question I should be asking also is,what does your car weigh and which SS springs do you have???
Re: SS SPRING CARS. [Re: MIKES_DUSTER] #673250
04/20/10 01:43 PM
04/20/10 01:43 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
3140# without me and I have the 002/003 spring package.
I don't have immediate access to my car right now (@ a freinds garage) as I work on my '71 Charger.
Just took the hanger (I may ave used the rear I did this long ago) and bored the hole out to accept the rear shackle tube then welded the tube to the bracket. Flipped the mount and welded it to the underside of the frame.
I'll get some pics as soon as I can if you are interested
Re: SS SPRING CARS. [Re: roadhazard] #673251
04/20/10 02:28 PM
04/20/10 02:28 PM
eastern Ky
hilbillyconquest Offline
eastern Ky
Re: SS SPRING CARS. [Re: hilbillyconquest] #673252
04/20/10 03:23 PM
04/20/10 03:23 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
2" lowering blocks
Re: SS SPRING CARS. [Re: JACK1440] #673253
04/20/10 11:44 PM
04/20/10 11:44 PM
Nice looking cuda!!!! Heres ours back in the late 80's with SS springs and (i think) 3" blocks.
Re: SS SPRING CARS. [Re: roadhazard] #673254
04/20/10 11:52 PM
04/20/10 11:52 PM
Please do!!!
Re: SS SPRING CARS. [Re: MIKES_DUSTER] #673255
04/20/10 11:59 PM
04/20/10 11:59 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Sitting
Working. 28" tall tire
Re: SS SPRING CARS. [Re: KillerBee] #673256
04/21/10 12:03 AM
04/21/10 12:03 AM
SSWWEEEEEEEEEEETTTTT CHALLENGER!!!!!! Whats in it and whats it run??
Page 2 of 3 1 2 3
