Post deleted by Defbob
[Re: blownzoom440]
#672846
04/17/10 09:05 PM
04/17/10 09:05 PM
Re: D DAY RESULTS!
#672847
04/17/10 09:08 PM
04/17/10 09:08 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Those are impressive numbers. Hopefully they will translate into impressive ET's at the track, WITH THE SAME BOOST LEVEL. Is your car legal to run 9's?
no cert yet.the 10pt cage is real good! ![](/ubbthreads/images/graemlins/thumbs.gif) I WONT CHANGE THE PULLEYS!
Good. You have the good block, so no worries there. If I were you, I'd start thinking about any possible weak areas in the drivetrain. With that much power on tap, marginal parts won't live for long. Hey, you might put on a clinic for some of these street driven blown Hemi boys!
![](/ubbthreads/images/graemlins/no.gif)
Re: D DAY RESULTS!
[Re: tboomer]
#672851
04/17/10 09:42 PM
04/17/10 09:42 PM
blownzoom440
ELYRIA,OH
Nice numbers,Mike!! Did ya call Greg about gaskets?
Koffels has the gaskets.
Re: D DAY RESULTS!
[Re: tboomer]
#672853
04/17/10 09:52 PM
04/17/10 09:52 PM
blownzoom440
ELYRIA,OH
Cool!! I have to make some calls monday to get some...
i need some valve cover gaskets my thick fiber/rubber 1's leaked on the dyno bad. ![](/ubbthreads/images/graemlins/rant.gif)
Re: D DAY RESULTS!
[Re: rickstershemi]
#672857
04/18/10 08:16 AM
04/18/10 08:16 AM
blownzoom440
ELYRIA,OH
Very nice #'s Mike, it's gonna be a beast for sure ![](/ubbthreads/images/graemlins/thumbs.gif)
Rickster
Thank you!my quest was for a little more hp but mainly a safer block [KP440] insted of the stock block i was using. the bigger carbs did help with IAT and more hp whatever it does at the track i will be happy with and just tune on it and have fun. i am no bracket racer .i just like to have fun and be as safe as i can. the carbs need some tuning as the cruise A/F was 12.3 at 3k rpm warming on the dyno and that was after opening up thge idle air bleeds to 70 from 55 and 1/4 turn out on the idle screw total.i have a wideband and EGT and those should help. we will se what she does at the track. ![](/ubbthreads/images/graemlins/stirthepot.gif) Mike. ![](/ubbthreads/images/graemlins/wave.gif)
Re: D DAY RESULTS!
[Re: blownzoom440]
#672858
04/18/10 08:33 AM
04/18/10 08:33 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Was this on Koffels dyno.....if so I would be a little suspect...just saw a guy on Yellowbullet that made over 850hp with a w5 408 just couple weeks ago.....he was getting slammed over there.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
Re: D DAY RESULTS!
[Re: instigator]
#672859
04/18/10 08:37 AM
04/18/10 08:37 AM
blownzoom440
ELYRIA,OH
yes it was at koffels.the dyno is a dead horse with me.the track will tell the story.it is sure to be faster tho.i ran the bigger carbs and less drive on the blower and went faster.
Re: D DAY RESULTS!
[Re: blownzoom440]
#672860
04/18/10 08:41 AM
04/18/10 08:41 AM
instigator
north cakalaky
All that matters is that you made more power and happy with what you did, atleast you were able to find the problems before you got it into the car and all buttoned up....good luck at the track ![](/ubbthreads/images/graemlins/thumbs.gif) When do you plan to have it in the car?
Re: D DAY RESULTS!
[Re: instigator]
#672861
04/18/10 08:53 AM
04/18/10 08:53 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
And yet, no mention of the cry for help from the Dyno cell to the office?
![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: WILD BILL]
#672862
04/18/10 09:01 AM
04/18/10 09:01 AM
Re: D DAY RESULTS!
#672863
04/18/10 09:09 AM
04/18/10 09:09 AM
blownzoom440
ELYRIA,OH
Alright, someone needs to spill the beans on what happened there!!
LOL!BIILLLL ![](/ubbthreads/images/graemlins/laugh2.gif)
