Page 2 of 6 1 2 3 4 5 6
Re: D DAY RESULTS! [Re: blownzoom440] #672844
04/17/10 08:58 PM
04/17/10 08:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Fair enuff...........
Re: D DAY RESULTS! #672845
04/17/10 08:58 PM
04/17/10 08:58 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
Those are impressive numbers. Hopefully they will translate into impressive ET's at the track, WITH THE SAME BOOST LEVEL.
Is your car legal to run 9's?
no cert yet.the 10pt cage is real good!
I WONT CHANGE THE PULLEYS!
Post deleted by Defbob [Re: blownzoom440] #672846
04/17/10 09:05 PM
04/17/10 09:05 PM
Re: D DAY RESULTS! #672847
04/17/10 09:08 PM
04/17/10 09:08 PM
ELYRIA,OH
ELYRIA,OH
Good. You have the good block, so no worries there.
If I were you, I'd start thinking about any possible weak areas in the drivetrain. With that much power on tap, marginal parts won't live for long.
Hey, you might put on a clinic for some of these street driven blown Hemi boys!
Re: D DAY RESULTS! [Re: blownzoom440] #672848
04/17/10 09:12 PM
04/17/10 09:12 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
What CID is that thing? & What cyl head is on it?
Re: D DAY RESULTS! [Re: RyanJ] #672849
04/17/10 09:24 PM
04/17/10 09:24 PM
tboomer Online work
tboomer  Online Work
Nice numbers,Mike!! Did ya call Greg about gaskets?
Re: D DAY RESULTS! [Re: RyanJ] #672850
04/17/10 09:40 PM
04/17/10 09:40 PM
ELYRIA,OH
ELYRIA,OH
it is a 446 3.75 stroke 4.351 bore with ported iron heads[346] 280int/180 ex at .600 .646/.631 lift 112lsa. 260/269 dur at .050 291/306 at .020.
Re: D DAY RESULTS! [Re: tboomer] #672851
04/17/10 09:42 PM
04/17/10 09:42 PM
ELYRIA,OH
ELYRIA,OH
Koffels has the gaskets.
Re: D DAY RESULTS! [Re: blownzoom440] #672852
04/17/10 09:46 PM
04/17/10 09:46 PM
tboomer Online work
tboomer  Online Work
Cool!! I have to make some calls monday to get some...
Re: D DAY RESULTS! [Re: tboomer] #672853
04/17/10 09:52 PM
04/17/10 09:52 PM
ELYRIA,OH
ELYRIA,OH
i need some valve cover gaskets my thick fiber/rubber 1's leaked on the dyno bad.
Re: D DAY RESULTS! [Re: blownzoom440] #672854
04/17/10 10:00 PM
04/17/10 10:00 PM
ELYRIA,OH
ELYRIA,OH
here is how my day started.fixing the water plug leaks.
Re: D DAY RESULTS! [Re: blownzoom440] #672855
04/17/10 10:01 PM
04/17/10 10:01 PM
ELYRIA,OH
ELYRIA,OH
2
Re: D DAY RESULTS! [Re: blownzoom440] #672856
04/17/10 10:25 PM
04/17/10 10:25 PM
Lehigh Acres, Florida
rickstershemi Offline
Very nice #'s Mike, it's gonna be a beast for sure
Rickster
Re: D DAY RESULTS! [Re: rickstershemi] #672857
04/18/10 08:16 AM
04/18/10 08:16 AM
ELYRIA,OH
ELYRIA,OH
Rickster
Thank you!my quest was for a little more hp but mainly a safer block [KP440] insted of the stock block i was using. the bigger carbs did help with IAT and more hp whatever it does at the track i will be happy with and just tune on it and have fun. i am no bracket racer .i just like to have fun and be as safe as i can.
the carbs need some tuning as the cruise A/F was 12.3 at 3k rpm warming on the dyno and that was after opening up thge idle air bleeds to 70 from 55 and 1/4 turn out on the idle screw total.i have a wideband and EGT and those should help.
we will se what she does at the track.
Mike.
Re: D DAY RESULTS! [Re: blownzoom440] #672858
04/18/10 08:33 AM
04/18/10 08:33 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Was this on Koffels dyno.....if so I would be a little suspect...just saw a guy on Yellowbullet that made over 850hp with a w5 408 just couple weeks ago.....he was getting slammed over there.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: D DAY RESULTS! [Re: instigator] #672859
04/18/10 08:37 AM
04/18/10 08:37 AM
ELYRIA,OH
ELYRIA,OH
yes it was at koffels.the dyno is a dead horse with me.the track will tell the story.it is sure to be faster tho.i ran the bigger carbs and less drive on the blower and went faster.
Re: D DAY RESULTS! [Re: blownzoom440] #672860
04/18/10 08:41 AM
04/18/10 08:41 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
All that matters is that you made more power and happy with what you did, atleast you were able to find the problems before you got it into the car and all buttoned up....good luck at the track
When do you plan to have it in the car?
65 Barracuda
Re: D DAY RESULTS! [Re: instigator] #672861
04/18/10 08:53 AM
04/18/10 08:53 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
And yet, no mention of the cry for help from the Dyno cell to the office?
Post deleted by Defbob [Re: WILD BILL] #672862
04/18/10 09:01 AM
04/18/10 09:01 AM
Re: D DAY RESULTS! #672863
04/18/10 09:09 AM
04/18/10 09:09 AM
ELYRIA,OH
ELYRIA,OH
Alright, someone needs to spill the beans on what happened there!!
LOL!BIILLLL
