MP Electronic Ignition Kit do you need a voltage reg??
#672720
04/17/10 05:32 PM
04/17/10 05:32 PM
Posts: 341 New Jersey
U_Code_Cuda
New Jersey
Probable a stupid question... I have a MP electronic Ignition kit and I am getting ready to install it with a Evans Wiring engine harness made for a electronic ignition. The harness has the plug for the ECU and also a plug for a Voltage Regulator ![](/ubbthreads/images/graemlins/shruggy.gif) The MP instructions do not show a diagram or need for a voltage reg....Other than being mentioned in helpful suggestions for race applications only.... I don't mind running one just want to make sure it is OK to.. Also, will the ballast resistor that comes with a Orange box work with a Chrome ECU... Thanks,
1970 R/T Challenger 4-speed 1971 Demon 340 3-speed
Re: MP Electronic Ignition Kit do you need a voltage reg??
[Re: U_Code_Cuda]
#672721
04/17/10 06:10 PM
04/17/10 06:10 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
voltage regulator has nothing to do with ignition, even they are related.
Voltage regulator is related with CHARGING system. Only wire what links them is the ign switch source ( blue wire )
[Re: NachoRT74]
#672725
04/18/10 07:42 AM
04/18/10 07:42 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Oh and by the way, YOU NEED a regulator... if not, won't have charge from alternator so batery will dye and not even GOD will fire up your engine back
Depends on your intended usage. If on the street yes you need a charging system but there are many race cars that run without one. So the "NEED" is relative to the application and usage.
[Re: NachoRT74]
#672727
04/18/10 02:38 PM
04/18/10 02:38 PM
U_Code_Cuda
New Jersey
Thank You guys, I will be using it on my 410 stroker in my Demon...It will need a volt reg... thanks, I lost my bearing because the car was completely apart when I bought it and have not done a full restoration in some years....
