4 barrel intake & carb for 68 383? #672687
04/17/10 04:40 PM
04/17/10 04:40 PM
NV
bss Offline OP
bss  Offline OP
NV
I'm looking for some recommendations for an easy bolt in affair to liven up my satellite sport. This is just a driver application; cam is stock and single 2.5" exhaust, so I just want something simple with a little more grunt than the stock 2bbl (which is hammered and needs to be replaced anyways.)
Re: 4 barrel intake & carb for 68 383? [Re: bss] #672688
04/17/10 04:52 PM
04/17/10 04:52 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
I would get a cheap eddy DP4B dual plane from ebay (paid $81 for a clean CH4 the other day ) and a thunder series 650.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: 4 barrel intake & carb for 68 383? [Re: bss] #672689
04/17/10 04:52 PM
04/17/10 04:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
383 performer or my pick 383 performer RPM
will work great with a little room to grow.
http://chucker54.stores.yahoo.net/edelbrock5.html
or this
http://chucker54.stores.yahoo.net/383400duelpl.html
Re: 4 barrel intake & carb for 68 383? [Re: gamagoat6x6] #672690
04/17/10 04:52 PM
04/17/10 04:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That too!
Re: 4 barrel intake & carb for 68 383? [Re: gamagoat6x6] #672691
04/17/10 04:56 PM
04/17/10 04:56 PM
NV
bss Offline OP
bss  Offline OP
NV
Thanks, that's kinda what I was thinking.
Should be eddy 1805 for this application, right?
Re: 4 barrel intake & carb for 68 383? [Re: bss] #672692
04/17/10 05:06 PM
04/17/10 05:06 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
yes lookey hear
http://cgi.ebay.com/ebaymotors/weiand-38...c#ht_500wt_1099
and hear
http://cgi.ebay.com/ebaymotors/vintage-o...9#ht_500wt_1099
Re: 4 barrel intake & carb for 68 383? [Re: bss] #672693
04/17/10 09:54 PM
04/17/10 09:54 PM
I'd locate an iron B manifold & if it's a square bore I'd get an eddy 1406 and (best way) if it's a spreadbore I'd have Demonsizzler build you a thermoquad
Re: 4 barrel intake & carb for 68 383? [Re: RapidRobert] #672694
04/17/10 11:05 PM
04/17/10 11:05 PM
East Central Illinois
jeff57 Offline
jeff57  Offline
my son has a 68 sport sattelite w/ 69 383 and we put a cast iron 68 4 bbl intake and a 600cfm vac sec holley, electric choke. starts great and runs very good. carb was $269.00 from jegs and intake was $20.00 at swap meet. no dinkin around just install and go. jeff57
Re: 4 barrel intake & carb for 68 383? [Re: bss] #672695
04/18/10 12:28 AM
04/18/10 12:28 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Go with the four barrel intake and Carter AVS carb
off the 68-70 Road Runner 383HP engine. Good STOCK
manifold, dirt cheap, trouble free (other than being heavy!) and has heat provision for those
cold mornings. Use a Carter 650, or Edelbrock 650
AVS STYLE carb with it. Anything larger WOULD BE OVERKILL with the stock cam, so choose wisely.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
