With no car, to keep this engine from rusting up, it needed to run every now and then. To keep it from going to waste, my solution was this.
Project needed 2x10's, 2x4's , outdoor screws, 20 amp ign switch, external starter switch. $20 bucks worth of stuff.
The 2x10 rails support the side oil pan lips. A back T holds up the bellhousing. Level it modifing the back T support.
A start stand can help to baseline carbs, time distributors, and do problem solving where "swap with known good part" is possible.
AWESOME NOISE CANNON!
