how much pressure does a power steering pump put out #67219
06/04/08 05:36 AM
06/04/08 05:36 AM
grand junction,colorado
ron_hertzberg Offline OP
hi folks
just wondering how much pressure a pump
puts out.the high pressure hose on my truck
cracked,and is leaking.would like to put a
new hose on it,myself.to save some $$$$.
the truck is a 1976 dodge d200 crew cab.
with a 440 in it.
ron
Re: how much pressure does a power steering pump put out [Re: ron_hertzberg] #67220
06/04/08 06:24 AM
06/04/08 06:24 AM
you can change the hose yourself. just make sure it's a high pressure hose and not fuel line or something like it. in other words,
the pressure is enough that it does require a high pressure hose.
Re: how much pressure does a power steering pump put out #67221
06/04/08 09:42 AM
06/04/08 09:42 AM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Pressure depends on the application but it`s anywhere fron 900 to 1200 psi. Probably 1000 to 1100 in your truck. Get the correct hose.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
