Re: reproduction broadcast sheet
[Re: DPelletier]
#672076
04/22/10 01:57 PM
04/22/10 01:57 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
I sent the 2 T/A broadcast sheets I found in my car to the cars owner years ago free of charge (I even paid for the postage) and would do the same today. A few years later the dealer sales paperwork for my car turned up and the seller wanted a pretty penny for it considering it wasn't worth anything to anybody but me. I eventually broke down and bought my sales packet. The guy who had it did put a lot of work sorting through a bunch of decades old paperwork to find documentation for specific cars, so he deserved compensation for that, but it is still a good question as to how much is reasonable for selling paperwork to the only person in the world it has value to? As far as sending a broadcast sheet one finds in his car to the owner of the car the sheet goes with, other than postage, there is no justification to charge anything IMO. But if someone collected a bunch of sheets over the years from cars they parted or found in cars he owned that had non-matching sheets, and then put time into sorting them out and trying to track down the cars they belonged to, then I think he deserves some compensation for his time.
[Re: DPelletier]
#672077
04/22/10 02:50 PM
04/22/10 02:50 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
To me, an original fender tag, broadcast sheet, factory invoice or window sticker is a unique page of history.
My definitions;
Original - This one is obvious.
Reproduction - An exact copy of the original with NOTHING guessed at.
Fake - Someone had to guess at something to make it, SPDs & VONs are commonly pulled out of thin air as two examples.
The first two do not alter history in any way, the fakes do.
I also believe that any item found should be free to the legal owner of the car. (My definition of legal does not include rebodied cars, I have denied items to folks who have cars with legal issues.)
With over 7000 items here waiting to be claimed for free (even the ones I had to buy), I try & set a good example for everyone.
That is how I feel about it & I am not going to argue with anyone that feels differently, I have better things do do with my time.
[Re: Alaskan_TA]
#672078
04/22/10 03:08 PM
04/22/10 03:08 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Ok....I have to disagree with some of the logic here...
Lets say you have two identical cars, both RESTORED equally yet one has lots of documentation and the other has none.
Are you saying both cars have the same value?
I don't believe so....
In fact if I had a very rare unique car and someone one offered to sell me the original BCS I would gladly pay a reasonable amount for it, same as a numbers matching engine or transmission, because in my opinion, all those things add value to a car.
CHECK OUT MY NEW WEB SITE !
[Re: Mastershake340]
#672080
04/22/10 03:34 PM
04/22/10 03:34 PM
It is definitely an admirable gesture to be benevolent with something of perceived (or actual) value but the point I was trying to make had to do with the actual vehicle. Prior to the Broadcast sheet being found, what changed about the car? How did finding the paperwork change anything regarding what the car was or represented? Nothing! The guy wanted another $1500 for finding the Broadcast sheet. In essence, the seller was taking a lean against the "new found" value of the vehicle. The logic has to work in both directions. You shouldn't be able to use the paperwork to SIGNIFICANTLY increase the value of a vehicle that has been manipulated or messed with. If a car (that is no longer original) can be verified with a Broadcast sheet, then why can't an all original car be the verification to obtain reproduction paperwork? For instance, lets say that you find a 440 Six Pack that no longer has it's original engine. The color has also been changed from what it originally was. The VIN plate and fender tag verify what the car was prior to being converted and altered. If that car was sold, would it be less valuable because the Broadcast Sheet was missing? Would the EXACT same vehicle be worth MORE just because the Broadcast Sheet was with it? Is the value of ANY car based on what IT actually is or what a piece of paper says it is? Pretty soon we will be discussing whether a tree makes noise when it falls IF no one is around to hear it!
#672084
04/22/10 06:54 PM
04/22/10 06:54 PM
Posts: 4,700 North Central USA (MN-WI area)
MuscleMopars
Finding the broadcast sheet changed everything. It validated/verified/authenticated what the car REALLY is and that makes it more valuable/desirable/marketable. I had a previous owner hold a broadcast sheet ransom from me once. My car was a Black Hemi RR with a very unusual stripe combination. Until that sheet showed up there was no way to prove the color and stripe combination was authentic to my car. So did getting the broadcast sheet change things. Yes!!!. The car would have cost me much more had the sheet been with it when I bought it. The second owner was the one that had the sheet, I bought the car from the 4th owner. So, paying his ransom was justified but certainly not what I would have done. If I had the sheet or any form of documentation for a car belonging to someone else it would be given free to the owner, only a gesture of appreciation would be necessary. I also have another Black 69 RR with V21 hood stripes and V7R Red accent stripes. I have two broadcast sheets, the original window sticker and the original fender tag for that car! Without all of that stuff I would have never even looked at buying that car. To me, factory authentication of rare colors, options, etc is important and is what drives the values. That's why clones are worth less than fully documented factory built cars. An analogy of a gum wrapper to a broadcast sheet is absurd!
Thanks, Eric email eric@musclemopars.com 715-426-HEMI (Shop) 612-669-CARS (Cell and Texts)Go to my Moparts "Profile" to see my web site
[Re: anlauto]
#672086
04/22/10 07:29 PM
04/22/10 07:29 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
You must be a very rich man
I usully ignore you for reasons of my own. You know what assuming does? It fits you.
I cleared about $3000.00 for 2008.
2009 was better, $7802.00
The "fundraiser" I did here at the end of 2009 fed me for a month.
I have had less than 60 hours of work so far this year.
I just sold one of my cars so I could keep my house a little longer, hopefully long enough to sell it too.
Never assume anything about something you know absolutely nothing about.
[Re: MuscleMopars]
#672087
04/22/10 07:32 PM
04/22/10 07:32 PM
...Finding the broadcast sheet changed everything......So did getting the broadcast sheet change things. Yes!!!.
With all due respect, you have confused your sense of awareness with reality. The vehicle did not change! Your AWARENESS of the vehicle changed. You still had to "do" or "undo" whatever stage the vehicle was in at that particular time. Unless you own the real version of the car "CHRISTINE", I doubt that IT did anything to "change" what it was!
As far as the "gum wrapper" scenario, it is quite accurate. Both (broadcast sheets & gum wrappers) were a means to facilitate an end result for the MAIN PRODUCT. The Broadcast Sheets were "trash" once they served their purpose the same as the gum wrapper. Once you removed it...it became trash! Don't get me wrong. Both are important UNTIL they have served their purpose. Once again you have attempted to rationalize your perception of importance to explain the reality of the situation. Broadcast Sheets were NEVER considered an important piece of documentation by the Factory AFTER they served their purpose.
You don't like the gum wrapper analogy...how about this one? How many of us have ever assembled a Bar-B-Que Pit? Those instructions are VERY important during the build process are they not? What happens to them after the assembly is complete? Do you guys frame and laminate the Bar-B-Que Pit "build instructions" and keep them as a sacred piece of documentation? I doubt that anybody does. The Build Sheets were the same thing for the assembly line workers. Nothing more than a list of instructions on how to assemble the vehicle! After that.....throw them away!!! It is the Hobby that has made Build Sheets the sacred icons that they have become today.
#672088
04/22/10 08:37 PM
04/22/10 08:37 PM
Posts: 116 MAIne
MoparABE
MAIne
With all due respect, you have confused your sense of awareness with reality....Once again you have attempted to rationalize your perception of importance to explain the reality of the situation.
Broadcast sheets are factory trash, I do not recall reading anyone saying the factory intended for them to be the golden ticket 40 years after their original use.
The factory never intended for these cars to be around 40 years later.
The reality of the situation is that in the real world, with real transactions occuring everyday, the buildsheet does add value.
It is an added validation and verification above and beyond the fender tag, VIN tag, window sticker etc. of what the factory workers built.
Would you buy a prize poodle for top dollar w/out a pedigree? I think not...The same applys here.
With real money changing hands, buildsheet=added value. That is the reality.
John
[Re: MoparABE]
#672089
04/22/10 08:51 PM
04/22/10 08:51 PM
It adds intrinsic value John. It does not change the "reality" of what the car is. If you have been following this thread almost everything you stated has already been expressed in various ways. One of the pitfalls of a Broadcast Sheet (as it relates to current market value) is that it can make a car of lessor value (a basket case, an incorrect restoration, etc...) more valuable because of what it COULD be, rather than what it actually is.
#672091
04/22/10 09:06 PM
04/22/10 09:06 PM
Posts: 116 MAIne
MoparABE
MAIne
I get what you are typing but who determines the value? The seller?, the buyer?, the Mopar gods?
Would you agree that a car is only worth as much as a potential buyer is willing to spend be it an OE winner, incorrect restoration or basket case.
I see your point in let's say an auction format but in any other scenario, I have to think anyone holding a broadcast sheet in high regard is doing their homework before a purchase is made.
I don't think anyone is buying a body shell, cool-whip container of bolts and a broadcast sheet and smiling on their way home that they just scored $$$! lol.
[Re: MoparABE]
#672092
04/22/10 09:10 PM
04/22/10 09:10 PM
The Window Sticker and Factory Invoice is the Holy Grail of paperwork. It tells EVERYTHING and MUCH MORE than the Broadcast Sheet. The Broadcast Sheet does not tell the actual production or sell date of the car, the Dealership it was sold to, the routing code from the Plant to the Dealership, The Dealer Code, the Zone Code, the wholesale price of the vehicle, the E.H. & O/markup costs, the hold back amount, the key codes, the list #'s, the Financier holding the Title, etc.... As I said in an earlier post, the Hobby has been brainwashed into thinking something that is not factually accurate. The Invoice AND the Window Sticker holds 100% more validity regarding documentation than ANY Broadcast Sheet.
#672093
04/22/10 09:10 PM
04/22/10 09:10 PM
anlauto
Let me get this straight.... birth certificates Diamonds gum wrappers BBQ instructions poodles
Did I miss any?
#672094
04/22/10 09:14 PM
04/22/10 09:14 PM
anlauto
That's a load of crap.... Those documents metioned won't tell you carb numbers, shock part numbers, colour of the steering column...ETC...ETC...ETC...ETC...ETC...ETC...ETC...ETC...ETC...ETC...
#672095
04/22/10 09:16 PM
04/22/10 09:16 PM
Posts: 116 MAIne
MoparABE
MAIne
I understand that point, I did type that it was an ADDED validation. To the restorer however, the broadcast sheet has far more useful information relating to parts implementation.
