What autolite spark plug for 915 headed racecar #671623
04/16/10 05:10 PM
04/16/10 05:10 PM
Cumberland, MD
Supersonic Offline OP
Cumberland, MD
I have ran the autolite 75 for years, but i cannot find them anywhere. I think they were discontinued, will it be ok to run the 85's or are they too hot?
Re: What autolite spark plug for 915 headed racecar [Re: Supersonic] #671624
04/16/10 05:56 PM
04/16/10 05:56 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I get mine from Advance Auto Parts.
You have to order them in. Just ask for #AR75 I run #AR73 and they are about 2.00/ea.
Hope this helps
Re: What autolite spark plug for 915 headed racecar [Re: roadhazard] #671625
04/16/10 06:23 PM
04/16/10 06:23 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i like the cad plated ones (silver) vrs teh black oxide ones....
silver is easier to read the tune up..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: What autolite spark plug for 915 headed racecar [Re: roadhazard] #671626
04/16/10 07:32 PM
04/16/10 07:32 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
Hope this helps
do you have to run a short plug for header clearance
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: What autolite spark plug for 915 headed racecar [Re: Supersonic] #671627
04/17/10 12:22 AM
04/17/10 12:22 AM
85 is a resitor plug that is the same heat range as the 75, if my memory is serving me correctly Have your autoparts store due a cross check on that
