what would cause 3rd gear clutches to roast?
#671484
04/16/10 01:52 PM
04/16/10 01:52 PM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
Had my coronet in the trans shop to replace a leaky front seal on a trans they rebuilt 2 years ago. Street/ strip coronet, ~550 flywheel hp. Drvoe the car for 3 seasons per year, 3 trips to the strip. He said the rear clutchpack was fried, but the other were ok. Had "blue" clutches in it, he's replacing them with reds. $470.- Any ideas what could have happened?
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
Re: what would cause 3rd gear clutches to roast?
[Re: whiplash]
#671485
04/16/10 03:34 PM
04/16/10 03:34 PM
Posts: 16,928 NC
440Jim
NC
Check your wording. In a torqueflite transmission, the front clutch engages with 3rd gear. This is sometimes referred to as the direct clutch because 3rd gear is direct drive, ie 1 to 1 ratio.
The rear clutch is engaged in all forward gears (1,2,3) and stays applied during shifts. It is sometimes referred to the forward clutch (not to be confused with front). If this clutch pack is burned up, it usually is due to a failure in the transmission (seal, rings, etc). In a properly working transmission, these should look like new year after year, after year...
[Re: whiplash]
#671487
04/16/10 03:41 PM
04/16/10 03:41 PM
Posts: 2,926 A shed in England
Tig
A shed in England
Could be the rear drum piston seal. It won't hold the clutch pack if it goes, they'll slip and overheat but I'm no expert
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#671488
04/16/10 03:42 PM
04/16/10 03:42 PM
Posts: 30,454 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Yes .. it COULD BE that - more likely the seal rolled-over and holding the piston up. But THEN you would have terrible engagement into reverse.
[Re: dOoC]
#671489
04/16/10 04:30 PM
04/16/10 04:30 PM
Tig
A shed in England
The caveat is "I'm no expert" Seriously though, thanks, I've learnt something
[Re: dOoC]
#671491
04/17/10 05:47 PM
04/17/10 05:47 PM
Posts: 25,892 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A strong Reverse isn't always a good indicator of front clutch sealing, the line pressure triples in Reverse so a weak clutch will often perform well at the higher pressure.
[Re: whiplash]
#671493
04/17/10 08:30 PM
04/17/10 08:30 PM
Posts: 16,928 NC
440Jim
NC
OK, which clutch pack was fried? The title says 3rd gear (front) and the post says rear...
[Re: 440Jim]
#671494
04/19/10 08:56 AM
04/19/10 08:56 AM
whiplash
Summit, NJ
Sorry, guys,
The 3rd gear clutch pack was glazed over, not completely fried. The trans guy did not like the look of it, so he went from blue clutches to reds. He also said there was a "wave" rings in there and he replaced it with a snap ring, supposedly stronger.
You can tell I don't know S**T about tflites.
now they are saying the leak I went in for originally may be due to a cracked converter???
