Re: do mopars just get low oil psi or is it just mine?
[Re: MoparforLife]
#671463
04/16/10 02:21 PM
04/16/10 02:21 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
My old 318 had 280K and at idle hot had like 10 psi.Ran for 4 years till I sold it and was running good after at least 3 more years that I know of.My 440 hi press hi vol pump has 80 cold and never drops below 65.My kis 62 413 carries 60 cold and minimum 45 hot.Rocky
Chrysler Firepower
[Re: stumpy]
#671464
04/16/10 03:32 PM
04/16/10 03:32 PM
Posts: 2,682 Clinton Twp. Michigan
coronet1966d
What oil gauge, what temp and what idle speed?
its an autometer short sweep electric 0-100psi
temp at idle is about 150 but it gets as high as 180
idle speed is about 1000
[Re: radar]
#671465
04/16/10 03:36 PM
04/16/10 03:36 PM
coronet1966d
My fresh build (small block) had a high volume pump. I seized it with a small piece of trash that got sucked in. I replaced it with a melling standard flow. My gauge still reads 10-15 at idle (900 rpm) and stays at or above 10psi per 1000rpm.
Gotta be loose bearing clearances? I also run the purple 10w30 synthetic.
yours sounds exactly like mine. (minus the seized oil pump part) this is a tight fresh engine with no more than 40 miles on it. a machineist did the lower end i assembled the rest
[Re: 5spdcuda]
#671474
04/16/10 05:46 PM
04/16/10 05:46 PM
coronet1966d
Clearances are probably on the loose side. Also high volume isn't the same as high pressure. I use a high pressure spring in any modified engine. With 20-50 weight oil my cold pressure is 75-80 psi. Hot idle is 40 psi, 30 psi if it's been run hard. Hot pressure at 2000 rpm is 60-65 psi. Pressure is 5 psi lower when using thinner oils. Most stock Mopars run 45-50 psi at 2000 rpm hot and anything from 15-30 psi at hot idle.
where can i get a high pressure spring?
[Re: Hoof Hearted]
#671477
04/16/10 09:03 PM
04/16/10 09:03 PM
Posts: 30,489 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
Corny ... it sound like you have a L O S S E L Y clearanced motor.
I'm guessing he meant L O O S E L Y
but I agree.
Oooooops !
...and me thimks your machinist needs to go back to FIRST GRADE !
[Re: dOc …]
#671478
04/16/10 09:19 PM
04/16/10 09:19 PM
Posts: 15,487 Florida
scratchnfotraction
I beg to differ here electric guages just show its working some and IMO are not a reliable as a mech guage I had the same thing till I went back to the mech autometer gauge i say put a mech on and check it first before working on something thats not broke my sb 318 holds 25 hot idle in gear at 850rpms 75 at 2500rpms almost 250,000 miles on it my BB used engine 75,000 miles was low pessure on elect gauge and flickerd the stock oil light in the dash swaped to the mech gauge now its up around 70 hot and 30 at hot idle sender was going bad maybe,it would be at 30lbs on mech gauge and flicking the oil light on the elect gauge compairing the 2 at the same time cant believe all you have in that 440 and its on the loose side did you do any oil mods? full groove bearings? did you get your seal fixed? how was the lifter bores?? in spec on the bore size? IMO,I would double check with mech gauge first move to see if the gauge is correct result will vary by gauge,IMHO
