Chrome ignition box #671218
04/15/10 11:03 PM
04/15/10 11:03 PM
kalamazoo, MI.
VIPERDUST Offline OP
kalamazoo, MI.
Replacing motor in the 66' sport fury, and replacing the ignition system. I have the mopar chrome box, and have all the wires labled, but I need to know which side of the ballast resistor does the one wire mount to. I can test with a amp / ohm meter, so I need to know which side of the resistor. Thanks, Matt
Re: Chrome ignition box [Re: VIPERDUST] #671219
04/15/10 11:08 PM
04/15/10 11:08 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Re: Chrome ignition box [Re: Hotwheelsjr] #671220
04/15/10 11:13 PM
04/15/10 11:13 PM
kalamazoo, MI.
kalamazoo, MI.
Thanks HW, I hope I can figure out which side is which, but it won't be too hard. Just power up and test the run side [12 volt side] Right?
Re: Chrome ignition box [Re: VIPERDUST] #671221
04/15/10 11:29 PM
04/15/10 11:29 PM
Hotwheelsjr Offline
Hotwheelsjr  Offline
The resistor doesn't care what side is connected to what -- you just want to make sure your + wire from your coil is on the opposite side of the wire from the ECU. I wasn't sure what you meant by "one wire" so I figured the diagram would be best for you. You also want to make sure your "start" wire is on the same side as the + coil wire and the "run" wire is on the side of the ECU. I forget what colors those wires are without breaking out the shop manual. If need be, I can do that too...
Re: Chrome ignition box [Re: Hotwheelsjr] #671222
04/16/10 12:07 AM
04/16/10 12:07 AM
kalamazoo, MI.
kalamazoo, MI.
I think you answered my question, I have all the wires labled when I took it off my duster when I replaced it with a 6al. Just wanted to make sure which side of the ballast it went to. Thanks HW..........Matt
Re: Chrome ignition box [Re: VIPERDUST] #671223
04/16/10 09:06 AM
04/16/10 09:06 AM
Hotwheelsjr Offline
Hotwheelsjr  Offline
No prob! If you run into probs let me know -- I can take a look at one of my cars and take pics if I have to. I have the chrome ECU in 2 of the 3 cars at my house -- the 3rd is running a 6al.
Re: Chrome ignition box [Re: Hotwheelsjr] #671224
06/14/10 03:47 PM
06/14/10 03:47 PM
Marcell, MN
68 Roadrunner Offline
Marcell, MN
I was doing a search for ignition boxes and found this thread. I hooked up my new electronic ignition exactly like the diagram above and it would only have spark when the engine was cranking. The tech guy told me the ballast resistor was bad and they sent me a new one. It still does the same thing. So I wired it up without the ballast resistor. Basically key on power to the coil and the ignition module. It runs like crap. Running it in the garage in park it isn't too bad but under a load it is terrible. I have checked what I know how to and can't find a problem. It seems like ignition though since it is worse under a load. I have the Proform kit with the orange box. (Jegs)
1968 Roadrunner 383 auto .060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: Chrome ignition box [Re: 68 Roadrunner] #671225
06/15/10 08:58 AM
06/15/10 08:58 AM
Marcell, MN
Marcell, MN
No one???
