Re: Chrome ignition box
[Re: VIPERDUST]
#671223
04/16/10 09:06 AM
04/16/10 09:06 AM
Posts: 10,693 Surface of the Sun, AZ
Hotwheelsjr
I think you answered my question, I have all the wires labled when I took it off my duster when I replaced it with a 6al. Just wanted to make sure which side of the ballast it went to. Thanks HW..........Matt
No prob! If you run into probs let me know -- I can take a look at one of my cars and take pics if I have to. I have the chrome ECU in 2 of the 3 cars at my house -- the 3rd is running a 6al.
[Re: Hotwheelsjr]
#671224
06/14/10 03:47 PM
06/14/10 03:47 PM
Posts: 130 Marcell, MN
68 Roadrunner
Marcell, MN
I was doing a search for ignition boxes and found this thread. I hooked up my new electronic ignition exactly like the diagram above and it would only have spark when the engine was cranking. The tech guy told me the ballast resistor was bad and they sent me a new one. It still does the same thing. So I wired it up without the ballast resistor. Basically key on power to the coil and the ignition module. It runs like crap. Running it in the garage in park it isn't too bad but under a load it is terrible. I have checked what I know how to and can't find a problem. It seems like ignition though since it is worse under a load. I have the Proform kit with the orange box. (Jegs)
1968 Roadrunner 383 auto
.060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
[Re: 68 Roadrunner]
#671225
06/15/10 08:58 AM
06/15/10 08:58 AM
68 Roadrunner
Marcell, MN
No one???
