Re: pinion angle again
[Re: GEORGE68HEMIRR]
#671139
04/15/10 11:44 PM
04/15/10 11:44 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
shims or cut the mounts and re-weld. either will work. just be careful with the welding, don't want to warp an axle tube.
as far as how much angle on the pinion you need...I've learned that there is no magic number after reading everything online. some will say 3-4 degrees, others say 5-7. some will say whatever it takes to get 0 degrees under WOT with spring wrap up at it's max.
do you have a vibration now? I'd say drive it, see how it feels, and adjust as needed from there.
**Photobucket sucks**
#671140
04/15/10 11:44 PM
04/15/10 11:44 PM
Posts: 43,207 Bend,OR USA
Cab_Burge
thanks josh....i have shims but was thinking of replacing and welding in new spring perches..have them too...just confused and trying to figure this out
Best bet is to remove and replace the spring pads,reposition the rear end housing with the pinion nose down to what angle you want and tack weld it in place. Remove it for the final welds, you might want to think about placing a strap, 3/16 to 1/4 thick by one inch wide,across the rear end housing from the ends of the spring perches to the other end as a brace, like a V. Forget the adpater shims
[Re: 70Cuda383]
#671141
04/16/10 12:29 AM
04/16/10 12:29 AM
Posts: 878 hudson valley n.y.
GEORGE68HEMIRR
super street
super street
hudson valley n.y.
well i guess i am at i think plus 3 so if i nose down the pinion minus 9 degrees that would set me at minus 6....would this be the right way of doing this i havent driven the car yet because i just installed the gear vendors overdrive and i ordered a shorter driveshaft .....i am just trying to get this set right.....its mostly a street car but it does see the strip 4-5 times a year.....i usually set the pinion snubber 1 inch from the floor
[Re: Cab_Burge]
#671142
04/16/10 12:36 AM
04/16/10 12:36 AM
GEORGE68HEMIRR
super street
super street
hudson valley n.y.
these danas are pretty bullet proof right?you really think i need a brace?....what happens with the cover? do you think i should nose down the pinion minus 9 degrees to get it to minus 6?
#671146
04/16/10 09:29 AM
04/16/10 09:29 AM
Posts: 705 Michigan
Hemiroid
He was talking about adding a piece of flatstock that is wrapped around the axle tube in a "u" shape to support the ends of the perches.
[Re: Hemiroid]
#671147
04/16/10 10:27 AM
04/16/10 10:27 AM
GEORGE68HEMIRR
super street
super street
hudson valley n.y.
thats a good idea....now thats clear....thanks
#671148
04/16/10 02:32 PM
04/16/10 02:32 PM
Posts: 1,472 Overland Park, KS.
Joshs68
Overland Park, KS.
if you are at plus 3* now and that is parallel with the crank center line then consider that zero. so if you shim for zero on your gauge then that would be 3* down
