Looking for some pics of tunnel ram/dual carb linkage. #670458
04/15/10 12:24 PM
04/15/10 12:24 PM
Redding,CA USA
440charger500 Offline OP
Redding,CA USA
I just need some idea's. I dont like the way mine works so post up some pics if you could.
Thanks Anthony
Re: Looking for some pics of tunnel ram/dual carb linkage. [Re: 440charger500] #670459
04/15/10 12:47 PM
04/15/10 12:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How are your carbs mounted... north/south or east/west
Re: Looking for some pics of tunnel ram/dual carb linkage. [Re: MR_P_BODY] #670460
04/15/10 12:50 PM
04/15/10 12:50 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Re: Looking for some pics of tunnel ram/dual carb linkage. [Re: DJVCuda] #670461
04/15/10 12:52 PM
04/15/10 12:52 PM
Redding,CA USA
Redding,CA USA
Holley carbs mounted sideways.
Re: Looking for some pics of tunnel ram/dual carb linkage. [Re: 440charger500] #670462
04/15/10 01:06 PM
04/15/10 01:06 PM
Cab_Burge Online work
Cab_Burge  Online Work
I hope this picture is clear enough to see the linkage on mine with the carbs mounted sideways As already mentioned the pedal effort is more than a single four barrel so a good cable and stable mount is needed BTW, this is the Enderle type linkage, all adjsutable heim joints on the ends for reduced friction Their kits are infinetly adjustable, evry good stuff Not cheap tho There are other kits avalable with hiem joints also, shop around before deciding
Re: Looking for some pics of tunnel ram/dual carb linkage. [Re: Cab_Burge] #670463
04/15/10 02:08 PM
04/15/10 02:08 PM
Redding,CA USA
Redding,CA USA
That picture is good I can see what I need to get. Or maybe I'll just make it.
Re: Looking for some pics of tunnel ram/dual carb linkage. [Re: 440charger500] #670464
04/15/10 06:42 PM
04/15/10 06:42 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
If your creative, it can be made for just a few dollars....
Look
Post deleted by Defbob [Re: MR_P_BODY] #670465
04/15/10 06:50 PM
04/15/10 06:50 PM
Post deleted by Defbob #670466
04/15/10 07:30 PM
04/15/10 07:30 PM
Re: Looking for some pics of tunnel ram/dual carb linkage. #670467
04/15/10 07:38 PM
04/15/10 07:38 PM
mo
moparbud Offline
moparbud  Offline
mo
mine
Re: Looking for some pics of tunnel ram/dual carb linkage. [Re: 440charger500] #670468
04/15/10 08:59 PM
04/15/10 08:59 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
Enderle linkage and a pair of 1000 cfm holleys
Re: Looking for some pics of tunnel ram/dual carb linkage. [Re: Plymouth340] #670469
04/15/10 09:04 PM
04/15/10 09:04 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Post deleted by Defbob #670470
04/15/10 09:28 PM
04/15/10 09:28 PM
Re: Looking for some pics of tunnel ram/dual carb linkage. #670471
04/15/10 09:43 PM
04/15/10 09:43 PM
A push/pull deal.
that's the very first hemi tunnel ram manifold ever. notice no plenum and still had air horns holley 6214 carbs
And dual distributors, That pictures is a classic
Re: Looking for some pics of tunnel ram/dual carb linkage. [Re: 440charger500] #670472
04/16/10 12:39 AM
04/16/10 12:39 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i made my own after looking at some pics from here
bought some 1/4 inch heim joints off e bay got some keyway stock(square stock) threaded a couple of rods think it turned out pretty good
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Looking for some pics of tunnel ram/dual carb linkage. [Re: toplescuda] #670473
04/16/10 02:11 AM
04/16/10 02:11 AM
Redding,CA USA
Redding,CA USA
Well mine is alive and running. It took awhile to free up the some tension and increase the travel for full throttle but its working now. Thanks for all the pics it helped.
Anthony
Post deleted by Defbob [Re: Cab_Burge] #670474
04/16/10 09:04 AM
04/16/10 09:04 AM
Post deleted by Defbob #670475
04/16/10 09:09 AM
04/16/10 09:09 AM
Post deleted by Defbob #670476
04/16/10 09:13 AM
04/16/10 09:13 AM
Re: Looking for some pics of tunnel ram/dual carb linkage. #670477
04/16/10 09:22 AM
04/16/10 09:22 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The Enderle stuff you see in most these pictures is pretty much the industry standard. You can get kits from Enderle, BDS, The Blower Shop, Kinsler ect etc.
