88 318 to 360 swap questions - help deciding #670413
04/15/10 12:55 PM
04/15/10 12:55 PM
Port Saint Lucie, FL
ChallengerGary Offline OP
Okay - seems like my 318 currently residing in my 1988 2WD Ram Charger is about to give up the ghost. It's got a sound on acceleration that sounds suspiciously like a rod knock, there is a lifter that does not want to pump up, and the oil pressure is erratic. Oh yeah, and it bogs like a beyotch as well.
SOOOOO, long story short. Found an '88 318 on Craigslist that the the guy says was running great when he stripped the truck. It is complete and has all accessories and wiring harnesses with it. Basically, he said he tried to sell the truck as a running driving truck but nobody wanted it. Since he knew the engine was good, he kept it. He only wants $299 for it.
OOORRR, I have a "free" 360 I can get that is something like a '77 or so. Not sure about it's internal status but it's free. If I go this route, what should I do, swap my intake and Throttle Body onto the 360? Should I leave the current heads on the 360 or put on the ones from the 318?
I am really confused, I like the idea of having the extra power from a bigger engine but also want to consider budgetary and time constraints.
I need to decide before my current engine leaves me stranded...
Stick with a 318 or swap to 360
single choice
Votes accepted starting: 04/15/10 11:55 AM
You must vote before you can view the results of this poll.
Re: 88 318 to 360 swap questions - help deciding [Re: ChallengerGary] #670414
04/15/10 05:51 PM
04/15/10 05:51 PM
Anybody willing to put in their
Re: 88 318 to 360 swap questions - help deciding [Re: ChallengerGary] #670415
04/15/10 05:51 PM
04/15/10 05:51 PM
IMGTX Offline
IMGTX  Offline
If you want to have fun I suggest you get the 360 fast and pull the pan. Check the bearings and decide if you want to risk it.
If it's a no go then go get the 318. That being said. Both engines are questionable IMHO. If you can't drive it or see it run you have no idea if it is any good.
Re: 88 318 to 360 swap questions - help deciding [Re: IMGTX] #670416
04/15/10 05:54 PM
04/15/10 05:54 PM
The 360 isn't going anywhere - it's in a customer's car at my shop. He said I could have it, he's going with a crate motor. So I guess I should pop it out of there tonight and take a look see at what's going on inside of it. You're right it can't hurt to look at it.
Re: 88 318 to 360 swap questions - help deciding [Re: ChallengerGary] #670417
04/15/10 06:15 PM
04/15/10 06:15 PM
Bama
BigDawg72 Offline
BigDawg72  Offline
Bama
I have a perfectly good 318 with less than 500 miles on it sitting in my shop floor and a new 360 sitting between the fenderwells waiting to be plumbed and fired up! My Chally is my toy and I wanted more than the 318 could reasonably be expected to give. Budget wise I should still be running the 318 that would have probably outlasted me. Just my
If both motors need freshening up... I say go with the 360.
Re: 88 318 to 360 swap questions - help deciding [Re: BigDawg72] #670418
04/15/10 06:19 PM
04/15/10 06:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not too sure how the stock electronics will like the 360. Not too much out there in the way of upgrades for the old Mopar TBI setup. Not too great a system either, imo.
For simplicities sake the 318 would be a better choice, however, the 360 would be more fun.
If you have to smog it, I see you are in the DFW area, a carb is out.
Don't be the exception.
Re: 88 318 to 360 swap questions - help deciding [Re: Supercuda] #670419
04/15/10 06:25 PM
04/15/10 06:25 PM
Yes, I do have to smog it but I would think that I can get it to pass emissions with a decent running carb'd 360. Of course, I d have to to keep the catalytic converter on it...
Re: 88 318 to 360 swap questions - help deciding [Re: ChallengerGary] #670420
04/16/10 07:25 AM
04/16/10 07:25 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd get the 318, and send the cam in your current 318 out to bullet to get reground using their HR259/316 lobes for intake and exhaust, and put that into the new motor, reusing the lifters, pushrods, etc.
2017 Grand Cherokee Overland
Re: 88 318 to 360 swap questions - help deciding [Re: patrick] #670421
04/16/10 09:16 AM
04/16/10 09:16 AM
scratchnfotraction Offline
droping in the other 318 is plug and play with less tuneing for smog check IMHO
yea yea yea 360 more fun and less MPGS also
less work,less "mod o frying",less $ with plug and play
Re: 88 318 to 360 swap questions - help deciding [Re: scratchnfotraction] #670422
04/16/10 01:51 PM
04/16/10 01:51 PM
Update - Well - strange thing happened last night, all of a sudden she started to run better and is making no funny noises...So, I went ahead and put in the new fuel pump and sock I had bought last week, figuring what the heck, it'll need it anyways. This morning, fire it up and it has never run better since I got it LOL!!! I guess maybe I put the fear of God in it or something yesterday.
At any rate, I think I may either pick up the other '88 318 or see if I can maybe find an '88 360 to hold in the wings. Meanwhile, since the 360 is free, I think I will pull it from the car it's sitting in and take a look inside of it. Maybe I will take my time and build stroker for some future project
Thanks for all of your help and advice
Re: 88 318 to 360 swap questions - help deciding [Re: ChallengerGary] #670423
04/16/10 06:05 PM
04/16/10 06:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Haven't had to deal with TX smog, yet, biut the only Ram with a carb in 88 was the 1 ton. If TX smog is setup amything like other state's smog they know what you should have and it's not gonna pass the visual inspection, which is before the sniff test.
Re: 88 318 to 360 swap questions - help deciding [Re: ChallengerGary] #670424
04/16/10 08:06 PM
04/16/10 08:06 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
I would run the 360 and try to get a harness for a 88 360 truck to it looks right for smog, if you're handy with split loom and friction tape you can disguise the reworked 318 harness.
As long as it looks right you should be ok, I used to pass smog in a 86 D100 with a 360 running a MP 280/.474 cam, hedman longtubes and a edelbrock performer rpm, I had cats(dual exhaust), stock air pump and a 318-4 spec Qjet on it.
Re: 88 318 to 360 swap questions - help deciding [Re: ChallengerGary] #670425
04/17/10 12:39 PM
04/17/10 12:39 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Excellent idea !!!
Re: 88 318 to 360 swap questions - help deciding [Re: Wedgeman] #670426
04/18/10 11:56 AM
04/18/10 11:56 AM
SE Kansas
I
indytex96 Offline
indytex96  Offline
I
SE Kansas
Not trying to highjack, but I am planning a similar swap in a 90 Ramcharger. Going from the 318 to an older model 360 and was told in a prior post that I wouldn't be able to run the 318's TBI on it because of the computer. Highly recommended going to carb so my question is what do need to expect to have to do to convert it over as far as wiring harnesses, distributer, in tank pump, etc... Like I said, sorry for jumping in, but this seems to go along with the prior question. Thanks!!!
Re: 88 318 to 360 swap questions - help deciding [Re: indytex96] #670427
04/18/10 05:26 PM
04/18/10 05:26 PM
gots to run a fuelpump reg for the carb
hack into the wire harness to get the alt to charge (wire in an VR with plug IIRC)
another hack in the wireharness for the tank fuel pump to work
change the throttle cable over to carb style
add a elect dist with a vac advance can
just to mention a few things to over come
or swap the entire wire harness to an a non pcm/TBI wire harness
I did that on my 88 440 truck
swaped the wire harness back to an 85 harness to drop the tbi crap all together
Re: 88 318 to 360 swap questions - help deciding [Re: scratchnfotraction] #670428
04/18/10 08:54 PM
04/18/10 08:54 PM
SE Kansas
I
indytex96 Offline
indytex96  Offline
I
SE Kansas
So to simplify things it would be easier if I just got a harness out of an 85? Then I could just hook it all up and regulate the fuel pump. Did 85's use the electronic ECU type distributor?
Re: 88 318 to 360 swap questions - help deciding [Re: indytex96] #670429
04/18/10 09:01 PM
04/18/10 09:01 PM
you would need to find a way to power the in tank pump with the 85 harness
you could just add a bumper pump to the line and on the frame though
yes 85 has the ecu and elect dist
you would need the steering colum and guage cluster along with the 85 harness
to simplify...dont know if thats the ez-est way or the cheapest way or the best way...its just what I have done on a couple
it is not that hard to hack the wire harness to keep all the stock harness..I am just not up on all of it and it was ez for me..faster too
Re: 88 318 to 360 swap questions - help deciding [Re: scratchnfotraction] #670430
04/19/10 08:20 AM
04/19/10 08:20 AM
SE Kansas
I
indytex96 Offline
indytex96  Offline
I
SE Kansas
Sounds like I'll be doing some splicing! Dumb question, I assume VR is voltage regulator, but what do you mean by IIRC?? (wire in an VR with plug IIRC)
Re: 88 318 to 360 swap questions - help deciding [Re: indytex96] #670431
04/19/10 10:17 AM
04/19/10 10:17 AM
IIRC = if I remember correctly
VR = volatage regulator
you will need to clip a VR plug from another wireharness to splice into yours
