easy electrical question #670187
04/15/10 08:57 AM
04/15/10 08:57 AM
Tampa, FL
Garranimal Offline OP
Tampa, FL
where is the best/easiest place to grab "switched" 12v under the hood.
Car is a '69 superbee if that makes a difference. Thanks in advance.
-Garrett
Tampa, FL
Re: easy electrical question [Re: Garranimal] #670188
04/15/10 09:08 AM
04/15/10 09:08 AM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
It kinda depends on what you're trying to power,you can use a relay and go 4 the coil,or at the start relay???Again it depends on what you're powering....
Re: easy electrical question [Re: Hemiruss] #670189
04/15/10 09:39 AM
04/15/10 09:39 AM
Tampa, FL
Tampa, FL
I am powering a digital spark box.
Re: easy electrical question [Re: Garranimal] #670190
04/15/10 09:41 AM
04/15/10 09:41 AM
If you have the later 2 field terminal alt/flat reg, the blue field wire at that particular alt field, otherwise the blue wire to the "ign" terminal of the voltage reg
