Installing rear seat belts in 70 Roadrunner #669409
04/14/10 01:10 AM
04/14/10 01:10 AM
Red Bluff, CA
W
WilliamHall Offline OP
super gas
super gas
W
Red Bluff, CA
I put new tubs in the Roadrunner which when I bought it had no rear seats. I can see the bolt that goes through the floor near center of floor which one side of the seat belt would attach to. Where does the other side of the seat belt attach to? Was it on the tub I just cut or am I overlooking another bolt hole?
Re: Installing rear seat belts in 70 Roadrunner [Re: WilliamHall] #669410
04/14/10 08:14 AM
04/14/10 08:14 AM
okla.
O
okie Offline
okie  Offline
O
okla.
I will look at the car when I go to the shop in a little while. There should be a bolt hole on each side of the hump and the side belts should mount on each side under the quater window. Good Luck! Ronnie
