Re: Thrust bearing clearence....
[Re: ragingram]
#669233
04/14/10 01:50 PM
04/14/10 01:50 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
I went out in the shop and looked in one of my Mopar service manuals, they don't show the width of the thrust surfaces on any of the motors ![](/ubbthreads/images/graemlins/rant.gif) I did measure several sets of main bearings, new and used and it looks like the width of the crankshaft should be between 2.218 and 2.220. The new Cleveite thust main bearing I.D.width is 2.225, several used one, Federal Moguls, are right at 2.223 and 2.224. IHTHs, BTW, it is not uncommon to find thrust bearing surface wear on a old top fuel crank, or any crank that had a clutch attached to it ![](/ubbthreads/images/graemlins/Twocents.gif)
