Oil Pan Part Number for a 64 with a BigBlock? #669051
04/13/10 06:34 PM
04/13/10 06:34 PM
GA
Boosted Offline OP
Boosted  Offline OP
GA
I need a deep oil pan for my 64 Fury with a 440 and the one that was on the car had the drag link through it. Anyone have the part number for this pan?
The people at summit does not have a clue
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Oil Pan Part Number for a 64 with a BigBlock? [Re: Boosted] #669052
04/13/10 06:45 PM
04/13/10 06:45 PM
New England
Tech Instructor Offline
New England
Here is a Milodon #31470 Super Stock pan.Not sure if it will fit your k-frame.Says will fit 65 so it could fit your k-frame.
Re: Oil Pan Part Number for a 64 with a BigBlock? [Re: Tech Instructor] #669053
04/13/10 07:28 PM
04/13/10 07:28 PM
GA
Boosted Offline OP
Boosted  Offline OP
GA
Thanks.. That was close.. it is 31420 for a pre 65
2011 RAM3500
Re: Oil Pan Part Number for a 64 with a BigBlock? [Re: Boosted] #669054
04/13/10 07:48 PM
04/13/10 07:48 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
The 31420 9in sump only has 3in clearance on my 64...I gotta plan ahead at the track.
The little old lady from Pasadena is back!
Re: Oil Pan Part Number for a 64 with a BigBlock? [Re: Barnstorm] #669055
04/14/10 08:24 AM
04/14/10 08:24 AM
GA
Boosted Offline OP
Boosted  Offline OP
GA
Great looking car and thanks for that information. What size front runner are you running? Any room for a ataller one? My car is going to be a street car and I need to make sure that my front runers are tall..
2011 RAM3500
Re: Oil Pan Part Number for a 64 with a BigBlock? [Re: Boosted] #669056
04/14/10 09:16 AM
04/14/10 09:16 AM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Front tires 7.10x15 Moroso's...maybe 26-27in..can't go bigger because of headder clearance. Front is tied down to limit wheelies to about 18in. Bad choice of pan for street IMO. You shouldn't need 10qts for a street/strip motor if you don't exceed 6500. Moroso must make a shallower pan that would work ok...Bill
Re: Oil Pan Part Number for a 64 with a BigBlock? [Re: Boosted] #669057
04/14/10 11:13 AM
04/14/10 11:13 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
This Milodon pan works good on the strip or street and I run it with 7 quarts.. I punched a hole in it so I could run an external line. Also use a modified windage tray.
