We have CAP uppers & dynamic strut rods fitted. Set the alignment yesterday. After five hours I got -.5 deg lhs and -.75deg on rhs camber. With 4.5 degrees of caster on both, I then gave up
It's a major chore, rolling the car backwards and forwards lifting the front end, adjustments etc AND when you alter one it effects the other. Last time I had a front end alignment done it cost like 40 quid ($60) and it took 1/2 an hour, he made it look easy
. In hindsite I wish I'd took it back there
but I'm having another go today.
I will say the front suspension lifts very easy with all the heim joints. It's an extreme difference compared to the stock polybushed stuff. Is it going to wheelstand higher and hit the sump on return? I'm slightly worried about that
Edit. Had another go, got 0 camber 5 degrees caster LHS 0 camber 5.75 degrees caster RHS. How accurate should you be? I'll set the RHS as the left, just having a cup 'o tea
2nd Edit. Set as LHS all within .1 degrees
. We'll see if it works in 2 weeks. Couple of wheelstands and I'll probably have to do it all again however
