Re: Neutral safety switch issues - starts in gear [Re: stumpy] #668266
04/13/10 06:46 PM
04/13/10 06:46 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yea I read that, but if cranks without the wire plugged, is still starter relay related... if doesn't crank with wire unplugged at relay, then is still the wire... no other posibility that I'm aware at least
( both test with NSS unplugged )
Re: Neutral safety switch issues - starts in gear [Re: NachoRT74] #668267
04/13/10 10:16 PM
04/13/10 10:16 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
It won't be a wire problem when he ran it directly from the switch to the relay. It is not possible with a new wire.
Re: Neutral safety switch issues - starts in gear [Re: stumpy] #668268
04/13/10 10:25 PM
04/13/10 10:25 PM
NC
Badfish67 Offline OP
NC
It will crank with the wire plugging in or not and in any gear. I'm thinking that somehow i'm bypassing the NSS...any ideas about that? I have a 6 switch Painless Wiring box. The "I" wire from the starter relay goes to the starter button in the Painless box and the other wire from the NSS goes to the "G" on the starter relay. Thats about it...
1967 Barracuda 360ci/727 9.723ET @139.44mph
Re: Neutral safety switch issues - starts in gear [Re: Badfish67] #668269
04/13/10 10:53 PM
04/13/10 10:53 PM
Grand Prairie,Texas
Grand Prairie,Texas
With the wire disconnected from the g terminal the engine should not turn over. You are having a relay problem if it does turn over. As asked before are you sure you don't have a relay for a stick car?
Re: Neutral safety switch issues - starts in gear [Re: stumpy] #668270
04/14/10 01:49 AM
04/14/10 01:49 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
This whole scenerio defies all logic regarding a NSS and/or the relay!!
The ONLY engineered way the starter can get juice is if the relay grounds .
The only other way is if the middle wire on the relay (the one that goes to the starter solenoid small terminal)gets 12 volts.
If there's no wire on the ground (G) side of the relay, then that tells me the relay is continuosly grounded. Yet a new relay doesn't fix the problem!!
Something is REALLY strange.
Re: Neutral safety switch issues - starts in gear [Re: Badfish67] #668271
04/14/10 07:28 AM
04/14/10 07:28 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Post a picture of the relays terminals you are using. Its not rocket science here, its an easy one minute to diagnose and fix problem
Re: Neutral safety switch issues - starts in gear [Re: NITROUSN] #668272
04/14/10 09:25 AM
04/14/10 09:25 AM
NC
NC
I just figured it out...for some reason years ago, I ran a wire from my starter button to the same terminal on the starter relay that holds the wire for the starter (which should have just went to the "I" terminal). I took off that wire and now it will only start in park or neutral. Thanks for all the help!!! Now I wont have to lie at tech inspection that I have a NSS
Re: Neutral safety switch issues - starts in gear [Re: Alikazam] #2482372
04/13/18 11:45 PM
04/13/18 11:45 PM
GA
56 windsor Offline
56 windsor  Offline
GA
go to Oriley and buy a 30 amp 4 pole relay. about 8 bucks on the shelf. Should have numbers 30,85, 86, and 87. 30 is a fused constant power supply. 87 is power out 12 volts. 87 goes to the solenoid. when activated 30 and 87 are like a single wire. 85 is ground that goes to NSS pin. 86 is what I call the trigger switch wire it comes from a temporary 12v power switch. the 86 is the lead wire for the coil in the relay, and the 85 is the ground. the NSS supplies the ground when in park or neutral. 85 and 86 makes the coil charge and closes the points and joins 30 and 87 together to put out 12 volts and start the car. you would probably run 86 from the ignition switch start. if you have a ford like a solenoid hook it to the s side small post. https://www.youtube.com/watch?v=46nlei-2e4k
