Wow!- is that tight- #668053
04/12/10 11:42 AM
04/12/10 11:42 AM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
I stuffed the hemi in my Cuda' last night. Holy crap is that a tight fit. How much will my engine twist/flop when I get on it? Should I chain it down? 71- 5 speed, 500hp, factory mounts, manifolds. Getting closer. Have to have it done by June 5th-
Re: Wow!- is that tight- [Re: Kirby] #668054
04/12/10 11:57 AM
04/12/10 11:57 AM
will my engine twist/flop when I get on it? Should I chain it down? 5 speed, 500hp,
(1) yes (2) yes (3) that's why EDIT dont forget the subframe connectors and consider a roll cage as much for the body flex/twist as safety.
