Combination valve Q #667884
04/12/10 08:45 AM
04/12/10 08:45 AM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
I'm looking for a combination valve for my 72 satellite w front disc/rear drum brakes. will this work?
http://cgi.ebay.com/ebaymotors/GM-Propor...=item2a0622f4fe
does it matter that i have 12" cop rotors in front?
i'd appreciate your help ...
Re: Combination valve Q [Re: 440sat72] #667885
04/12/10 10:12 AM
04/12/10 10:12 AM
I would not. (1) it's a general merchandise part (2) the proportioning most likely wont be right for you. I'd peruse the parts for sale here and get a B body one and add a rear aftermarket prop valve if desired to fine tune it or best would be to ask the Doc what he would recommend in the way of a Mopar part to get you close cause w the different calipers it skews your requirements.
Re: Combination valve Q [Re: RapidRobert] #667886
04/12/10 06:26 PM
04/12/10 06:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's more the size of the rear drums, than the front rotors, that require close attention to combination valve selection.
Don't be the exception.
Re: Combination valve Q [Re: Supercuda] #667887
04/12/10 09:59 PM
04/12/10 09:59 PM
Thank you for the enlightenment
