Post deleted by Defbob
[Re: Moparmal]
#667860
04/12/10 07:56 AM
04/12/10 07:56 AM
Re: 5.0 LEVER VS 4.2
[Re: turbobitt]
#667865
04/12/10 01:16 PM
04/12/10 01:16 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
The 904 can use the 5.0 lever. the surface area on the high gear drum is so much smaller then a 727, it needs the extra clamping force for holding power.
As for the release, as I remember the 2nd gear servo availilbe volume is much smaller then the 727, which means the same sized flow orfice will fill the hole faster (turn the band off quicker).
In the end it really doesn't matter much, as long as the direct clutch apply circuit in the valve body is timed to the 2nd gear band release. It's more in the valve body then anything...
Also, I agree 727's feel like they hang up at low speed shifts, but even with the playback tach/driveshaft recorder, I've never seen any evidence of it actually hanging up at full throttle. I mean remember, even if the band was off, the drum still has to accelerate from a dead stop anyway, so it will always feel a little harsh from the basic system design.
