Elec. fuel pump location
#667274
04/11/10 07:58 PM
04/11/10 07:58 PM
Posts: 106 MI.
mech440
MI.
Hey Guys... looking for input on where is the best place to mount an electric fuel pump, probably the holley blue or equivalent?? Instructions I've read on line say lower than tank? I don't want it hanging too low and I know it's supposed to be close to the tank. I'm installing it on a '66 belvedere ii. Where has everyone else mounted theirs?? As always Thanx a lot for all the help!
If it doesn't have a motor.....it's not a REAL sport
Re: Elec. fuel pump location
[Re: mech440]
#667275
04/11/10 09:21 PM
04/11/10 09:21 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
They want them lower than the tank so that they are gravity feed fuel and less of a chance of cavitating which could cuase a failure.
Nothing on mine is stock so pics of mine wont help you much
[Re: WILD BILL]
#667276
04/11/10 10:06 PM
04/11/10 10:06 PM
Posts: 106 MI.
mech440
MI.
Thanx for the info wild bill. I've read the install directions on line and understand they want it low and close to the tank but I was just curious as to what other have done? any pics would help greatly!! Thanx again all!!!
[Re: justinp61]
#667278
04/11/10 11:58 PM
04/11/10 11:58 PM
WILD BILL
BROOK PARK, OH
OK, you asked for it
My old system W/ holley black pump
New fuel systme I just finished up
Told ya nothing on m car was stock
Re: 383man
[Re: 383man]
#667281
04/12/10 12:43 AM
04/12/10 12:43 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
This is when I still had the old 8 3/4 in the car. Still in the same location. I bolted this plate up into the trunk, and then hung the pump off it, in front of the gas tank. front view from the rear I have noticed some cars react differently than others to fuel pump location. Not sure why. example I set up a 69 B body similiar to my own, and we could not get it to stop fuel starving with only a bung in the bottom of the tank. We had to use a tank with sump in it. It's never been a problem on mine, and mine was the faster of the two cars.
Re: 383man
[Re: dave571]
#667285
04/12/10 05:35 PM
04/12/10 05:35 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I like the way dave did it. Currently I have mine in the little pocket in front of the leaf spring. I have so far two tanks gone thru it and will go on a cruise this friday to check it out some more.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
