streatable 3½" exhaust?
#666977
04/11/10 04:27 PM
04/11/10 04:27 PM
Posts: 2,578 sweden
1Fast340
sweden
any advice on how to make a 3½" exhaust liveable on the street? would be nice being able to drive to the track without atracting every policecar in the country and being able to hear something else than a ringing sound in my ears when i get to the track would some 8x5x18" straight tru mufflers be anywhere close to quiet enough? i would like to avoid a x-pipe since im sick of that sound, maybe a h-pipe
Re: streatable 3½" exhaust?
[Re: 1Fast340]
#666979
04/11/10 06:11 PM
04/11/10 06:11 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
I have a three inch system on my car(no X or H pipe) that uses a set of Magnaflow 3x14 oval muffs mounted at the rear bumper, not noisy until wide open throttle . The motor is a 518 C.I. low deck pump stroker motor that runs 10:30 in the 1/4 at or above 128 MPH with the exhaust system on the car runs .04 ET faster in the 1/8 mile with the exhaust off compared to with it on, not worth taking it off I have not tried removing it at a 1/4 mile track so I don't really know how much better it would run in the 1/4 I had originally planned on having a 3.5 inch system installed on the car but the muffler shop forgot to order the 3.5 muffs and mandrel bends to do the job, I was moving and in a hurry so I let them use the three inch parts, no real gripes now
[Re: 1Fast340]
#666980
04/11/10 06:20 PM
04/11/10 06:20 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Not trying to be a wiseguy 1fast340 but do you think you really need a 3-1/2 inch system on a 340! The larger the exhaust the louder it is. I think you could easily get away with a 3 in. system with a set of Magnaflows that would be streetable and loose very little ET at the track! It would also be much easier to install and you could run it out the back past the bumper! Mike
[Re: Neil]
#666983
04/11/10 08:26 PM
04/11/10 08:26 PM
Posts: 17,923 Akron, Ohio
ProSport
Akron, Ohio
I run 3.5" pipes with 3.5" 'PYPES' brand Race Pro mufflers, stainless steel for $75 each. They are not LOUD and run just like open headers at the track, I love them. I've also ran Magnaflows with the same results but they're $110 each.
[Re: 1Fast340]
#666984
04/12/10 12:46 AM
04/12/10 12:46 AM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
My motorhome is 3" exhaust, and it's fairly QUIET. It has two Flowmaster 50 series mufflers.
1 3/4" headers go into 2 1/2" collectors. the two headpipes merge, and Y into a single 3" exhaust. Two Flowmaster 3" 50 series run in tandem, one after the other, then out the back. It's quiet, and I lovvve the sound.
I went with four mufflers on my Jensen, two large turbo mufflers into two Dynomax Bullets. Couldn't be happier.
I like mufflers run in tandem I guess....?
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#666985
04/12/10 12:54 AM
04/12/10 12:54 AM
Posts: 1,880 USA
Ron Silva
USA
This is 3-1/2" on an A-Body. These Mufflers are super quiet and did not slow down my Demon one bit when I put them on it. 3-1/2" all the way including the full "H" and a tapered cone down to a 3" in and out muffler.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#666990
04/12/10 01:23 AM
04/12/10 01:23 AM
Posts: 2,578 sweden
1Fast340
sweden
gues it may end up alitle loud then reason i would like it in 3½" is that there is a plan for a much more powerfull smallinch motor in just a few years time and this screwblown little 340 is just a step on my way so i get to drive this car alitle and learn alitle more about blown motors before i build a bad to the bones gen3 HEMI and im not all that bad at building exhaust for myself but i realy dont want to redo it more times than i have to.. i dont think 3½" to the back of the car would be a big problem since i run a fuelcell inside the car and the sparetire well has been replaced with flat sheetmetal, but it may be alitle frustrating with groundclearance thanks for the pics and advice it dont look to bad actualy
[Re: Ron Silva]
#666992
04/12/10 08:21 AM
04/12/10 08:21 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Ron- are those the large body turbo mufflers? I run the 17769 (center-offset 3" in/out/internal) in a big single on my car and it's a very nice sound, not too loud, especially with a 3" glasspack in the tailpipe (the big muffler is before the axle) as a resonator. by the time the exhaust has gotten back to the rear axle, it's cooled down and contracted enough that you don't need a huge tailpipe. unless you're pushing 1000+ HP you probably don't need 3.5" diameter muffs and tailpipes. you could always put cutouts in before the mufflers and then run 2.5" mufflers and tails for daily driving noise control.
[Re: Ron Silva]
#666993
04/12/10 09:23 AM
04/12/10 09:23 AM
Posts: 4,074 Mo.
racerx
Mo.
Drag i like the way those pipes exit out the rear
Re: 383man
[Re: 383man]
#666994
04/12/10 12:06 PM
04/12/10 12:06 PM
Posts: 2,578 sweden
1Fast340
sweden
3" with an H-pipe on my 63 street car. I use 1-3/4 headers that go to a 3" collector. Then into the H-pipe to Dyno-Max Ultra-Flow mufflers. Its not as loud as you would think. My sons 3" system on his Dart is louder with the Flow Master's. I always race thru the pipes as I never uncap it. I would think 3-1/2 would be fine if you run all the way out the back and use good mufflers. Ron
that looks pretty good how long are those ultra flows? and i understand teh thing about flowmasters, i used to have a set of there 40series deltaflows and they sound very nice and agresive but they are alitle on the wild side for me conserning interior sound and they realy wake up the whole neighbourhood
the mufflers i have in mind is very simmilar in bodysize to magnaflows 3½" raceseries but 4" longer bodyshell compared to magnaflows these appleracingmufflers are 18" long i gues i should try this then if i just get my headers completed
[Re: Ron Silva]
#666995
04/12/10 12:07 PM
04/12/10 12:07 PM
Posts: 2,578 sweden
1Fast340
sweden
that looks quit good also:) im getting some ideas here:)
[Re: 1Fast340]
#666996
04/12/10 12:43 PM
04/12/10 12:43 PM
Posts: 5,080 organ
maximum entropy
organ
i run 3.5s, with a 3.5 cross pipe, walker welded ultraflo welded oval straight through "mufflers", and turndowns. at cruise they are surprisingly quiet. at wide open throttle they are alarming! with tailpipes, they would probably sound almost normal, at light throttle, anyway. an hour is about the longest i can take w/o earplugs.
