Space Saver Spare Tires #666822
04/11/10 10:59 AM
04/11/10 10:59 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Were all the tires BF goodrich on mopars or did they change to the Goodyear tires later in production?
Re: Space Saver Spare Tires [Re: maxie] #666823
04/11/10 11:28 AM
04/11/10 11:28 AM
California
1970mopar Offline
1970mopar  Offline
California
BF Goodrich thru 1972 (BFGoodrich had an exclusive patent on the design) - then Goodyear in the later years
Re: Space Saver Spare Tires [Re: 1970mopar] #666824
04/11/10 12:05 PM
04/11/10 12:05 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
So the 73-74 E body cars used the Goodyear? So it doesnt have near the value or is as sought after
Re: Space Saver Spare Tires [Re: 1970mopar] #666825
04/11/10 12:10 PM
04/11/10 12:10 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
B.F Goodrich space savers were E-body only and not equipped in any Mopars that I am aware of after 1971.
72-74 E-body utilized a full size spare.
In the mid 70's F-78-14 Goodyears were in the trunks of Aspens, Volare's and Cordoba's.
People regularly claim and try and pass off the Goodyear F-78-14 as Cuda, Challenger spaceaver spares.
Re: Space Saver Spare Tires [Re: mccannix] #666826
04/11/10 12:58 PM
04/11/10 12:58 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
You can thank Galen Govier for that, he listed the the Aspen space saver wheel number as being correct for 70-71 E-Body Space Savers.
April 18, 1977 Aspen SpaceSaver Spare
Re: Space Saver Spare Tires [Re: Snoopy] #666827
04/11/10 03:20 PM
04/11/10 03:20 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I have a tire that has never been mounted is why I am asking. So it would be for a Aspen then?
Re: Space Saver Spare Tires [Re: maxie] #666828
04/11/10 03:40 PM
04/11/10 03:40 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
If it is an F-78-14 Goodyear, it would be correct on that 2944250 rim Snoopy shows, if you are not concerned with date codes, and would be right at home in the trunk of an Aspen.
Bear in mind, as with the B F Goodrich spacesaver tires, the same in Goodyear were used by a variety of other car manufacturers GM and Ford included.
Re: Space Saver Spare Tires [Re: mccannix] #666829
04/11/10 05:38 PM
04/11/10 05:38 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
It is a F-78-14 Goodyear. I just went and looked. So it is not for a mopar then
