New Best 10.001
#666771
04/11/10 09:34 AM
04/11/10 09:34 AM
Posts: 310 Michigan
412 SB Duster
We out for our first test&tune. One easy pass, Then I got two full passes in. first pass was 10.01 Then backed it up with a 10.001 with some tuning I'll get in the 9.90s. 60ft- 1.374 330ft- 4.034 660ft- 6.317 @ 107.40 1000ft-8.307 @ 122.50 1320ft-10.001 @ 132.54 Al
Re: New Best 10.001
[Re: cbarracuda]
#666775
04/11/10 10:09 AM
04/11/10 10:09 AM
Posts: 310 Michigan
412 SB Duster
73 Duster 3220 W/Driver Ladder bar 904 W/lowgear set. Dana60 W/4.30s 412ci SB 360-1 Indys 3.79 Callies JP gas port W/metric ring pack Comp solid NO Roller here 272@.50 570 lift Al
Post deleted by Defbob
[Re: mopar dave]
#666776
04/11/10 10:09 AM
04/11/10 10:09 AM
Re: New Best 10.001
[Re: 412 SB Duster]
#666782
04/11/10 11:01 AM
04/11/10 11:01 AM
Posts: 257 plainwell,michigan
1fastaspen
plainwell,michigan
yes craig did but it was not a full out pass he was on and off the gas not sure what was going on
75 duster 440 in the works
71 pro street cuda
Re: New Best 10.001
[Re: Ian]
#666784
04/11/10 11:40 AM
04/11/10 11:40 AM
Posts: 310 Michigan
412 SB Duster
No cam change, Just changed to the gas ported & metric ring pistons. along with going from 3280 to 3220# Want to run some of the 10oh stuff this year. If I can get into the 9.90s now it should run 10'0s in the heat. 412ci SB 360-1 Indys Indy intake 3.79 Callies JP gas port W/metric ring pack Comp solid NO Roller here 272@.50 570 lift 950 prosystem carb turboaction converter 4200 Al
Re: New Best 10.001
[Re: 412 SB Duster]
#666785
04/11/10 03:01 PM
04/11/10 03:01 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Don't they have a bathroom close to the staging lanes. That's all you might have needed
Congrats on the new best
[Re: WILD BILL]
#666786
04/11/10 04:23 PM
04/11/10 04:23 PM
Re: New Best 10.001
#666787
04/11/10 04:26 PM
04/11/10 04:26 PM
WILD BILL
BROOK PARK, OH
Re: New Best 10.001
[Re: 412 SB Duster]
#666788
04/11/10 05:17 PM
04/11/10 05:17 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
412ci SB 360-1 Indys Indy intake 3.79 Callies JP gas port W/metric ring pack Comp solid NO Roller here [Email]272@.50[/Email] 570 lift 950 prosystem carb turboaction converter 4200
Al
That is 266º/272º @ .050" solid.
