hemi bigfoot rockers ...hoping i didnt mess up...
#666038
04/10/10 01:04 PM
04/10/10 01:04 PM
Posts: 8,858 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
any of you older hemi guys remember a rocker setup called a bigfoot?(for 426) im hopping i didnt just make a $600 mistake the roller cam is spossed to have 595-600 lift(dont remember off top my head) the new springs are good to 650 lift the guy doing the heads asked if i had aftermarket rockers (rollers) i said no that i thought they were just stock rockers and i belive were like 1.5 to 1 the person i got the motor from said the rocker setup was a bigfoot rocker and thought it was 1.6 to one but wasent 100% sure ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) is there a way to check the rockers to know for sure? or anyone heard of a rocker set up like that as iv never heard of it i would guiess that possible to be a old pro stock/super stock part as the heads are dick landy stamped twin plug,s ralph ![](/ubbthreads/images/graemlins/whistling.gif)
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: hemi bigfoot rockers ...hoping i didnt mess up...
[Re: RUNCHARGER]
#666042
04/10/10 09:53 PM
04/10/10 09:53 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
well my concern was the fact that i thought the rockers were 1.5 and the springs were good to 650 lift and if there 1.6 then wouldnt that make it more then 650??? possible cause coil bind?
[Re: RUNCHARGER]
#666044
04/10/10 10:29 PM
04/10/10 10:29 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
The Comp 930's make a great higher lift flat tappet spring...I had a set that were installed at about 1.935 or so, and the cam lift was approaching .700..pretty good size for a flat solid. I will link a old topic I posted a while back when i was shopping for Hemi rocker arms... Those old stock rocker may havent been perfect but lots of guys have run them on roller approaching .750 lift...so they are up to the task.. https://board.moparts.org/ubbthreads/show...&PHPSESSID=
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#666045
04/10/10 10:32 PM
04/10/10 10:32 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
i have the rockers off the heads now how can i tell what the ratio is? where would i measure?
[Re: toplescuda]
#666046
04/10/10 10:43 PM
04/10/10 10:43 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
ok i went down in the garage and grabed a pair their have a brass bushing with the 2 small oiler holes the long one has fon one end and a 2 at the other end one one side and a p with a circle around it on the other side the short rocker just has the p wit circle around it a b that is barlet readible ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: toplescuda]
#666047
04/10/10 10:52 PM
04/10/10 10:52 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
this is ballpark lol but the long rocker measured (tape measure) 2 3/16-2 1/4 from from center where valve would touch and 1 1/2 from center to center to where pushrod would go short rocker 1 7/16 on valve side 13/16 inch on push rod side but that would all depend on where the adjuster is
[Re: toplescuda]
#666048
04/10/10 11:39 PM
04/10/10 11:39 PM
Bob_Coomer
Rock Springs
If the engine is still together, or you have a rocker arms on one of the intake and exh, it can be measured with a dial caliper if your carefull. Adjust the lash to zero. Measure from a good point on the retainer with the cam on the heel or base circle. Turn the engine over to max lift being careful and measure correctly. Find out gross lift and then what the cam card reads. on lobe lift. Do this several times until you get a couple repeated numbers. Divide the two. I know ICL and other things can make a diff. But I checked my cam this way and it was within .010 of what actual net lift is. Other way is too just measure lever point too fulcrum point simple math that way..It might be difficult doing this with out a good set of machinist mics and measuring equipment.
[Re: Bob_Coomer]
#666049
04/10/10 11:50 PM
04/10/10 11:50 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
no the short block is being hot tanked cam bearing and if all goes good short block assembled the heads are here and the stands are off the heads
Post deleted by Defbob
[Re: toplescuda]
#666050
04/11/10 12:35 AM
04/11/10 12:35 AM
[Re: Bob_Coomer]
#666052
04/11/10 02:49 PM
04/11/10 02:49 PM
[Re: toplescuda]
#666054
04/11/10 06:12 PM
04/11/10 06:12 PM
#666055
04/12/10 12:13 AM
04/12/10 12:13 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
how about a side by side shot showing the differance between the 2?
