440 Head Gaskets water passages don't match. Help!!!!
#665826
04/10/10 01:13 AM
04/10/10 01:13 AM
Posts: 227 Scottsdale, AZ
Cudalord
Scottsdale, AZ
Ok, I've been battling this overheating problem forever, and it has to be internal, because I've tried EVERYTHING else (please don't ask me if I have a fan shroud)!!! Now, I'm tearing down the motor and I bought some new head gaskets and I noticed something interesting. The water ports above/between the cylinders don't match up. The Felpro 8519PT-1 only has a "slit" in it, but there is a nice sized hole in the head and block obviously restricting the water flow. See pics. Do I have the wrong gasket? What do you recommend? Desperate and I want to get this done this weekend. NO theories, just answers please!!! Thanks in advance!
Re: 440 Head Gaskets water passages don't match. Help!!
[Re: dirtybee]
#665832
04/10/10 09:14 AM
04/10/10 09:14 AM
RapidRobert
At 1st I thought that was just a block pic for reference but if that is the "one" it (the block) for sure needs to be baked clean. W that amt of crud it will unfortunately never be right. I'd also (w a freeze plug/jb weld) plug the large irrregularly shaped large block water passage in the rear of each deck, as said punch out the slits to match the figure eight top passages AND drill an 1/2" (at least) hole in the block/deck/gasket between #3 and #5, and #4 and #6 cyls in the outer edge of the deck adding a completely new water passage. The proper place on this edge there's 2 outer head bolt holes and you want to drill the 1/2" passage "in/up" so that it makes a triangle w the 2 head bolt holes. 2 ex valves are paired at that point and that alot of blocks have NO passage there and it is exactly the spot that needs a passage and a large one at that. And an anti cavitation plate welded on the pump vanes and at least a 1-1 crank/wp pulley ratio. Good luck to you on this dilemma and holler on what you think & how it turns out
[Re: RapidRobert]
#665834
04/10/10 01:33 PM
04/10/10 01:33 PM
Cudalord
Scottsdale, AZ
There really isn't that much crud on it, most of it is just scaling and it brushed right off.
After doing more research on this, I've seen a lot of guys recommend drilling 3/8" holes through the head gasket to allow water through the two lower passages, and that's it.
Re: 440 Head Gaskets water passages don't match. Help!!!!
[Re: 52savoy]
#665837
03/17/12 10:41 PM
03/17/12 10:41 PM
Posts: 1,960 Kenosha, Wi
GOLDMYN
Kenosha, Wi
Hi, Has anybody had simliar problems with the felpro 1009 head gaskets?, I have an over heating issue and talked to Larry Shepard and he said he "punches" every set he uses. I had an engine shop rebuild my engine and I'm guessing they didn't know about this. any comments will be appreciated.
Semper Fi
[Re: Cudalord]
#665839
03/18/12 02:35 AM
03/18/12 02:35 AM
Posts: 16,482 Canada
CrAzYMoPaRGuY
Canada
Transfer slots are common discussion in Jensen Interceptor forums. Small engine compartments make cooling an issue.... I went to the Jensen Monday Club website, the tech section shows how to enlarge the transfer slots. I roughly tripled the width of the transfer slots on my Jensen's Felpro gaskets.
CrAzYMoPaRGuY
[Re: RapidRobert]
#665840
03/19/12 12:42 AM
03/19/12 12:42 AM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
Hundreds of thousands of big blocks have run that gasket as it comes out of the box and never had a problem.
The OP has an issue and doing what you suggest is a bandaid masking the problem.
[Re: 52savoy]
#665841
03/19/12 12:45 AM
03/19/12 12:45 AM
JohnRR
A gulag near you.
This discussion came up months ago.. There was a change in head gaskets, maybe in the late 70s or so. The round holes were eliminated in favor of slots. I locate the exact place where the holes need to be and repunch the head gasket. I have a set of FelPros done that way on a max wedge and I can't even get it to heat up now. Maybe a little to much flow now??
There was NEVER a round hole , the original head gaskets from my 69 383 have a rectangular shaped hole instead of the slit, no other holes added . I can't see it making a huge difference .
[Re: JohnRR]
#665843
03/19/12 09:35 AM
03/19/12 09:35 AM
GOLDMYN
Kenosha, Wi
Huge difference ?, My car is a 1971 Charger R/T that has the stock 22" radiator, I've got a "Glen-Ray" radiator and my car runs at 190 cruising and creeps to 200 at stop signs, IYHO would the change in gasket ie (punching a bigger hole" bring it down 5-10 degrees?...thanks
Semper Fi
[Re: GOLDMYN]
#665844
03/19/12 09:46 AM
03/19/12 09:46 AM
JohnRR
A gulag near you.
I don't think so, the holes in the block and the head are not directly over each other so making the holes bigger is going not to change this or make the connection between them that much greater.
That said sometime after 71 or so the factory did change that hole in the block to a figure 8, but they didn't change the head gasket.
Some claim to have seen lower temps by adding the 2 holes in the gasket where those lower holes are covered by the gasket but if I remember right this was on extreme race builds ???
I'm guessing your build is more than the 22" rad , especially if you had it done as a 2 row , is capable of cooling , though I don't know what your cooling system consists of .... rows in your core , thermo temp , shroud , fan type ...
This is the original head gasket from my 69 383 , it has a 18xxxxx part number on it .
[Re: JohnRR]
#665845
03/19/12 12:20 PM
03/19/12 12:20 PM
GOLDMYN
Kenosha, Wi
Thanks for your response, the radiator is 3 row 22", 180 stat,8 blade water pump, direct drive w/factory fan,factory spacer, factory shroud. Whats your thoughts on crusing at 190?, The cars does run good and doesn't ping, or puke, autometer temp guage, Thanks again!
Semper Fi
