A-Body 340 Motor mount Brackets #665787
04/09/10 11:29 PM
04/09/10 11:29 PM
New Jersey
U_Code_Cuda Offline OP
New Jersey
Anyone have photos of what a pair of factory motor mount brackets look like for a 1971 Demon 340. I am currently running the standard 3 bolt and 4 bolt straight brackets but, I am having major clearance problems on the pass side idler arm and header. Thought maybe I am running the wrong mounts...
Thanks,
1970 R/T Challenger 4-speed
1971 Demon 340 3-speed
Re: A-Body 340 Motor mount Brackets [Re: U_Code_Cuda] #665788
04/10/10 12:09 AM
04/10/10 12:09 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The biscuit holes should be oriented towards the front of the car on the mount brackets. If they are towards the rear, they are b/e brackets
This is a bracket from a 318 modded to fit the drivers side of a 340/360. Original 318 mount on the right.
