2.30" Hemi valves on a 4.255 bore #665578
04/09/10 07:28 PM
04/09/10 07:28 PM
closer to Canadian beer!
torkrules Offline OP
I'm neurotic
I'm neurotic
So I have a set of Stage V heads that have 2.30 valves. The edge of the bore near the intake valve needs to be relieved to make sure it clears. I took an old cometic gasket and traced out the relief in the gasket onto the deck and used a die grinder to add clearance.
Any one else do this or running the same thing? I just want to make sure I have enough clearance. The cometics are .027" thick. The valve pockets are wide enough, just concerned about the valve to bore just as the valve opens.
Re: 2.30" Hemi valves on a 4.255 bore [Re: torkrules] #665579
04/10/10 09:02 AM
04/10/10 09:02 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
You should only need a .023" deep relief ground @ 35* from bore centerline for the clearance you are trying to get.
Re: 2.30" Hemi valves on a 4.255 bore [Re: LSP] #665580
04/10/10 09:09 AM
04/10/10 09:09 AM
I'm neurotic
I'm neurotic
Thanks Looks like I'm good!
