Re: undercoating
[Re: Bob's71R/T]
#665400
04/09/10 05:16 PM
04/09/10 05:16 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I think it would depend on the condition of the rest of the car and rarity of the car. For example, is the rest of the car restored or is it original also? Is it a Hemi/440-6 car?
65 Barracuda 70 Challenger
Re: undercoating
[Re: sawdust]
#665402
04/09/10 06:14 PM
04/09/10 06:14 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I am curious,,,, what do you guys consider "factory undercoating" ?
I am truckless..
Re: undercoating
[Re: 340SHORTY]
#665403
04/09/10 09:21 PM
04/09/10 09:21 PM
"Factory" style undercoating is quite a bit different than what is offered today. The old "factory" undercoat had a higher base composition of petroleum Tar. The old stuff was thicker but the aspect that gave it the "original" look was the method by which it was applied. It was not sprayed on with a forced air (suction) setup but with a pressurized pot system. The material was forced into a large vat and the pressure was applied BEHIND the material via a pressure piston that forced the material through (and to) the application wand. The material came out EXTREMELY fast and HEAVY!! Large amounts of material could be quickly dispensed which is what gave the "correct" surface pattern that you see when documenting the unique appearance of a factory undercoating job!
Re: undercoating
#665404
04/10/10 12:48 AM
04/10/10 12:48 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I agree about the equipment and application methods,,, but still dont understand the "factory" terminolgy as it never was done at the "factory"...
I am truckless..
Re: undercoating
[Re: Alaskan_TA]
#665406
04/10/10 02:50 AM
04/10/10 02:50 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
are you positive Barry? I really would have to dissagree...
I am truckless..
Re: undercoating
[Re: 340SHORTY]
#665407
04/10/10 01:12 PM
04/10/10 01:12 PM
Of course it was done at the Factory! Where do you think the J55 undercoating option code (found on the Broadcast Sheet) was applied? It was listed on the broadcast sheet to be used for the build process just like the interior, engine, body moldings, vinyl top, tires, paint, etc.... A vehicle could have undercoat applied by the dealership after it was purchased but the factory undercoat was put on at...........the Factory!
Re: undercoating
[Re: 340SHORTY]
#665409
04/10/10 01:47 PM
04/10/10 01:47 PM
Posts: 2,304 WI
RestoRick
WI
All cars received wheelwell undercoating at the factory. Cars with the J55 sound deadener package were undercoated on the floor pans in addition to the wheelwells.
The factory applied undercoating is usually easy to distinguish because of it's distinct texture and if you scrape it smooth you can see fibers in it.
Re: undercoating
[Re: RestoRick]
#665410
04/10/10 01:51 PM
04/10/10 01:51 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Larry, If you get time, you should share your 'back in the day' undercoating story with us, I do not remember all the details. Barry
Re: undercoating
[Re: RestoRick]
#665411
04/10/10 02:24 PM
04/10/10 02:24 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Ok guys,, heres a lil insite... in late 72 and early 73. I worked for a company called Convoy Company in Kent Wa. Convoy was the forwarder of the new AMC, Ford, and Chrysler vehicles when they were sent to the dealers. Forwarders were used everywhere.. The vehicles would come to us on railcars,they wre unloaded and then we processed them. The first part of the processing was a bath, yes they would come in filthy. Some would have to be ran through the car wash more than once to get clean.. Next the cars that were coded for undercoating went through the undercoating bay...wheelwel or complete jobs Sorry guys but those cars came off the factory line and railcars like a babys bottom,,, nothing on them...didnt you ever wonder why there is no undercoating above the gas tank? The cars were then masked off , undercoated and then sent to the detail bays. The cars then were vacumed out, windows washed ect. Wanna ask where a lot of build sheets went? The cars then went to a mechanic who double checked all lighting, heater, radio ext to be working. The cars were then parked in their respective order to be transported to the dealers. We processed thousands of cars for Wa, Id, Mt and the fridged state of Ak...
I am truckless..
Re: undercoating
[Re: RestoRick]
#665413
04/10/10 08:23 PM
04/10/10 08:23 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
you bet the undercoating came in 35 gallon drums. It was pumped via the old style pumps that were air driven. The air pressure drove the pump that sucked and then pushed the goop to the spray gun. The spray gun was a Binks style of gun with a large tip. It attached to the pump with a long hose. There was 2 guys in the UC bay One was the sprayer and the other was the masker. It was a messy job. They would tape their sleeves, cuffs and necks and anywhere else to try be as clean as possible. They coated themselves with vasoline to help to stay clean. In the time that I was there, we had 4 different guys doing the spraying. There wasnt any set pattern as to how the UC was applied as long as the job got done...
I am truckless..
Re: undercoating
[Re: GKMOPAR]
#665415
04/11/10 01:02 AM
04/11/10 01:02 AM
Do undercoated cars also have a underhood pad?
A car with the J55 (undercoat) option would also have the under hood insulation pad included.
Re: undercoating
#665416
04/11/10 09:06 AM
04/11/10 09:06 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
340shorty, that is a great story. My car is coded J55 and whether the factory did it or the forwarder, it was on the car pretty heavy and really protected the floors well. BUT, I don't think we have really answered the original Poster's question. In my answer above, I was trying to find out more info. about the car because I think it would help us to answer his question. DISCLAIMER> I'm no expert so the following are just my thoughts. I would think if the car was a Survivor car, then value would not be hurt. If the car were Restored back to "factory specs" and the original undercoat was not removed and shot with fresh "factory style" undercoating during the restoration then the value might suffer. Some people may be concerned with what lies between the undercoat and steel. Maybe rust has started but is hard to see because of the undercoat. Also, since money was spent to make the rest of the car nice, it may seem like a shortcut was taken by not removing the undercoat to a potential buyer. As SAWDUST, said above, if the car was coded for it and it was Restored and the undercoating done "right" then value would not be hurt. All that being said. Many people (that are non-purist) like the Over-restored look (ie painted bottom) on a "Restofied" car. Therefore, your market for those who like the factory undercoat is smaller.
Re: undercoating
#665417
04/11/10 11:06 AM
04/11/10 11:06 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
There are exceptions.
T/As, AARs, The '69 A12 cars, shaker hood cars, etc. - no pad due to the fresh air hoods.
Re: undercoating
[Re: Alaskan_TA]
#665418
04/11/10 11:25 AM
04/11/10 11:25 AM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
How about Superbirds?
