flex plate question 73 charger #665327
04/09/10 03:57 PM
04/09/10 03:57 PM
Riverside R.I. U.S.A.
suit-case Offline OP
I have a 73 charger with a 400 and there is a ticking or clicking sound coming from the bell housing.I pulled the inspection cover and didn't find any cracks where it bolts to the torque converter,could this be cracked where it bolts to the crank or could this be the converter?
Thanks,Jim
Re: flex plate question 73 charger [Re: suit-case] #665328
04/09/10 04:09 PM
04/09/10 04:09 PM
douglasville,ga
ramrod Offline
ramrod  Offline
douglasville,ga
Pull one of the converter bolts and see if the bolt hole in the flex plate is elongated. If not, retorque the bolts. If that doesn't fix it, the flex plate could be loose/cracked at the crank or an internal converter problem.
I recently had a B&M converter that was blowing up and it sounded EXACTLY like a loose/cracked flex plate. That sound was intermittent though.
"That Plymouth had a Hemi with a Torqueflite." -Driver
Re: flex plate question 73 charger [Re: ramrod] #665329
04/09/10 04:31 PM
04/09/10 04:31 PM
Thanks I will check the bolt holes.This makes the sound constantly,I did see some circular scratch marks on the engine side of the flex plate and I think theres some fine metal shavings on the inside of the bellhousing.
