Re: Front end rebuild question, do you typically replace...
[Re: DaytonaTurbo]
#665259
04/09/10 05:30 PM
04/09/10 05:30 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Yeah the factory boots for the most part suck big time. I like the aftermarket polys but don't have any on my cars yet.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: DaytonaTurbo]
#665263
04/09/10 07:57 PM
04/09/10 07:57 PM
Posts: 1,164 Los Angeles, CA
JF_Moparts
Los Angeles, CA
On a front end rebuild, do you typically replace the idler arm, pitman arm, tie rod dust boots and ball joint dust boots? I'm ordering all my components and these are the ones I wonder if they need replacing. Thanks.
I replace the tie rod ends and the ball joints, which come with dust boots.
I don't replace the idler or pitman arms, unless there some compelling reason to do so.
[Re: DaytonaTurbo]
#665265
04/09/10 08:44 PM
04/09/10 08:44 PM
Posts: 842 Urbana, MD
bordin34
Urbana, MD
I am in the middle of my rebuild and the only special tool I needed was the ball joint socket. Everything else can be taken apart with normal tools , a BFH, vice grips, and a pickle fork or two. Also if you are reusing your torsion bars you will need the fancy removal tool or make your own non-scoring tool. I used vice grips because I am putting in new bars. You will need a shop to press you LCA and UCA bushings in and out. My Rebuild
[Re: bordin34]
#665266
04/09/10 11:42 PM
04/09/10 11:42 PM
Posts: 7,501 Minnesota
Hemi_Joel
Minnesota
When I do the front end on a 40 year old car, I replace all the wear parts. You can get an idler arm for $15 at Rockauto.com. Why not do it while it is all apart? ![](/ubbthreads/images/graemlins/Twocents.gif)
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
