Is a mini starter a worthwhile
#665147
04/09/10 12:44 PM
04/09/10 12:44 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Going to be installing my new motor real soon. The old standard starter had no problems, but I'm wondering if now is the time to upgrade to a mini. Car does have headers. It's a street-strip type of effort. I'm not made of money, but $70 could be found. It would just take away from my drag-radial tire budget.
Is this update worth the $$$ ?
Re: Is a mini starter a worthwhile
[Re: StukaJU87]
#665159
04/09/10 03:57 PM
04/09/10 03:57 PM
Posts: 15,487 Florida
scratchnfotraction
one could be a little smaller than the other I have 2 from the u-pull it for 14$ each had the first one rebuilt after it started clicking a lot after 2yrs of service,rebuild for 65$ for a total of 79$ on that one..still cheaper than new,been 5yrs now 2nd one from u-pull 14$ was on a 96-97 / v-6 1500 ram it was smaller and had a plastic plug for the small wire,so I had to splice it into my 85 wire it had been replace,has a napa sticker on it and was a new one not remaned.. for a total of 14$ spins super fast on the 440 truck same on the SB,can R&R the starter without R&R of the header on the sb also can R&R the header with out removing the starter with the hedman headers I miss the sound but not the slow batt killer 30lb ginny that I can barly hold up to the tranz now the 6lbs mini is a another story...the mini dont hurt as much when you drop it on your head under the car I will take 6lb knock on the head over a 30lbs one anyday
[Re: BDW]
#665161
04/09/10 04:20 PM
04/09/10 04:20 PM
scratchnfotraction
no,not if you get the one with the 2 studs on it,may need to remove an extention piece though..very ez..2 nuts its off the new one I got had the newr plug deal I did cut and splice the plug into my 85 truck to use it...I moved the one that had 2 studs to the 440 truck cause I did not want to cut the wires up...and I didnt want to go back to the u-pull to exchange it..it was rather new so..I kept it and made due..couldnt beat 14$ for it I was just say that I notice there was a size diff in the 2 and that the newer one had the plug to deal with so pick the one you need the first time..I should have noticed that when I got it I upgraded to the mini alt on the 440 in the sig pic also..it wired right up with a couple wire crimps and longer bolt/stock brackets
[Re: moparcanuk]
#665165
04/09/10 08:38 PM
04/09/10 08:38 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
If you can tolerate the sound. I refuse to use the mini. I have old style starters on everything, and have fired up 12.5:1 engines in the summer AZ heat with ease with the old style starters.
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: scratchnfotraction]
#665166
04/09/10 08:41 PM
04/09/10 08:41 PM
Posts: 1,565 tennessee
pushbutton
tennessee
my hedmans said stock shortolder type starter only
plenty romm for smaller though
Yea my mini wouldn't clear my cheap hedman's, had to use stock starter.
