Re: 70 Challenger having problems with Hemi Vapor Separator
[Re: Triggerfish]
#664934
04/09/10 12:58 AM
04/09/10 12:58 AM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
buzz separator should mount off right fuel pump bolt, should not hit alt?? did you mount it high. could be needle set stuck in carb, fired up few cars in fleet this month each one had carb problems from sitting all winter
MOPAR OR NO CAR
[Re: hemigod426]
#664935
04/09/10 01:11 AM
04/09/10 01:11 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Aaron, I'll check how he mounted it tomorrow & will probably install the 650's too. It ran last nite & drove it about 40 miles. No vapor lock, but after sitting traffic, I got on it & it started to stumble about 4500-5K. Thought the fuel was just too hot, but maybe its an issue w/ rear carb? Ran great on race gas & no problems at high rpms. Maybe this return line is letting too much fuel go back to the tank & starves the back carb? Should I put a regulator on the return line to allow more fuel to the back carb? Would a regulator near the carbs help?
[Re: Triggerfish]
#664936
04/09/10 01:20 AM
04/09/10 01:20 AM
hemigod426
test mech fuel pump flow, put small dail reg between pump and carb up line, think you should add small electric pump by tank,right when out line hit rail, will solve all vapor lock flow problems, with better steady flow/pressure
MOPAR OR NO CAR
[Re: hemigod426]
#664937
04/09/10 09:37 AM
04/09/10 09:37 AM
Triggerfish
Blairsden, CA
I was thinking about a small electric pump back by the tank, if I can find a quite one. Summit sells some small helper pumps, but don't know how quiet they are. I don't want the noise like my bro's Holley blue made. I'll check flow of pump & maybe the pump is weak. Ran great before the separator, except for the vapor lock issue, but race gas solved that, so must be related to vapor separator & return line setup. Put in the blaster coil last nite as you recommended, too.
[Re: Challenger 1]
#664939
04/09/10 12:42 PM
04/09/10 12:42 PM
Triggerfish
Blairsden, CA
Thanks & is that the diameter or the return orfice hole? What's the correct size or diameter?
[Re: Triggerfish]
#664940
04/09/10 02:23 PM
04/09/10 02:23 PM
Challenger 1
Cincinnati, Ohio
I'm not exactly sure what size it's supposed to be, but I think is around .062" like I posted above. I would think someone could back that up.
BTW I love your home town and state. Last year we drove from Reno to Vegas in our motorhome, I love it. Beautiful, was there last year for HAN! Have family in Truckee right next to Donner lake. ![](http://i21.photobucket.com/albums/b260/challenger19711/Phase%205/MVC-840S-1.jpg)
