Re: Doug Nash 5 speed
[Re: AndyF]
#662097
04/06/10 09:55 PM
04/06/10 09:55 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
It's a lot of work but well worth it.Just make sure you fab the tranny mount very strong with gussets.I looked at mount the other day and it's starting to flex I should have put a limiter on it when I added the extra ponies and bite Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#662098
04/07/10 07:37 PM
04/07/10 07:37 PM
Posts: 2,129 Vermont
TrWaters
Vermont
I bought a DN 5 speed with a Ford pilot shaft. Quicktime had a SB Mopar bellhousing for that application.
TR Waters
[Re: Acme Rocket]
#662100
04/08/10 03:10 AM
04/08/10 03:10 AM
Posts: 43,272 Bend,OR USA
Cab_Burge
Is it a strret or strip only trans?
[Re: rowin4]
#662107
04/11/10 09:32 PM
04/11/10 09:32 PM
fourgearsavoy
Rittman Ohio
I agree Call Liberty's and tell them what you are doing and I am sure they can make what you need.Also might want to go here www.umtrnorth.com because there are quite a few guys with tons of parts for Nash boxes. Gus
