Re: I give up, 440's just run HOT
[Re: 69chargeryeehaa]
#66214
06/06/08 09:00 PM
06/06/08 09:00 PM
Posts: 308 michigan
black64
michigan
whats your convertor , stock ?
yes, stock. everything is stock except for the new parts i just put on, eddy CH4B intake, and eddy 750 afb carb, TTi 2.5 exhaust with h-pipe, stock exhaust manifolds, 70+ voltage regulator with 3 wire alt, mp perf ele ign.....
If you did not have the problem before you put the above parts on it they must be the problem either the intake/carb or in the mp ignition. Since you mentioned running rough and dieing out it seems either a weak spark or lean air/fuel mixture when the engine gets warm which creats higher temps. What ignition module did you use? Where the parts new?
[Re: black64]
#66215
06/06/08 09:29 PM
06/06/08 09:29 PM
Posts: 227 Scottsdale, AZ
Cudalord
Scottsdale, AZ
I had this same exact problem. Drove me nuts, and I live in AZ, where it gets 110+ in the summer. At stoplights and drivethrus, my temp would creep up to 240! Here's what I did:
1.Installed B-Cool Radiator and overflow can. 2. Brand New Stock Water Pump, not high flow or anything like that. 3. Miloden 180 thermostat 4. Flexalite 210/220 dual puller fan (this was after trying highflow flex fan, HD Fan Clutch, New Viscous fan, etc etc etc - none of it helped) 5. Flushed and drained system til it ran clear, about 6 or 7 times...
Hope this helps, it worked for me. I didn't go through all the posts, but what do you have for an overflow can? This is important because when the radiator gets hot/pressurized, the excess fluid goes into the overflow, then is pulled back in when needed. I can't stress enough, check the small things. Make sure there's no air pockets or something like that.
Good luck, I feel your pain.
#66216
06/06/08 10:55 PM
06/06/08 10:55 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
my charger with a 440 does a similar thing. moving it will be locked in at about 170-180. at idle it will creep up, but if i turn on my electric fan, it stabilizes..im running a mild 440, be cool direct fit rad, flowkooler waterpump, 160 tstat,fixed flex fan, shroud, and a 16' pusher electric on the front. tranny runs through a seperate cooler, and not through the rad.
i, too, am running a rebuilt, carbed motor. block was tanked, etc...
i still don't like it. I don't want to have to use an electric as a crutch. I have always suspected the flowkooler or any high performance pump. I don't know why, but maybe the stock pump in the stock housing moved the coolant the most efficiently. maybe slapping on a superduperdeluxbignuts water pump screws that up..maybe they cavitate or just move the coolant too fast. lots of r and d went into this stuff years ago and we go throwing these parts on because it looks nice in the summit catalog.
I read a story of a guy with a kitcar cobra or something like that years ago who was running a smallblock ford that would just not stay cool. ended up that he was running a 'not quite right" water pump. got the right one and his trouble went away.. so maybe it's possible to be running a "stock" pump and still have the wrong one?
what's real strange is there are guys here running big motors on puny radiators with no trouble at all. no shrouds, stock systems......
[Re: Neil]
#66219
06/07/08 08:53 AM
06/07/08 08:53 AM
Bob is definitely right on the overbore, it can be a huge issue, especially if you have any core shift.
One thing that hasn't been mentioned is that it appears that some of the pump manufacturers are putting non-mopar impellers in their pumps. I saw one a friend had bought, (small block) and it had an impeller that was between the diameter of the small and large Mopar ones, with 8 blades. I think it was a GM impeller. I don't think anyone knows if the flow and pressure out of a pump like this is correct for a Mopar, or what speed it should really run.
#66220
06/08/08 12:10 PM
06/08/08 12:10 PM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
well, i have good news..... I've done everything i listed in my last post, and the car ran at 175-180 with the new pump, ect....but still ran a little crappy after about an hour of driving....so i changed the coil, and the problem disappeared completely. By the way, this weekend in toronto, it's been extremely hot out, 39*deg C, and very humid. perfect testing grounds. I can see a huge difference in water flow in the rad at idle, where before coolant would just barley move past the top, now at idle it's a very nice stream of coolant. Huge difference in cooling, the car runs great now, last night at a cruise night i was idling for 15mins in this heat, the car did get to 190, but not higher, the electric fan really makes a big difference at idle in gear stopped, it really keeps things under control. Funny, this is the 3rd coil i've tested, 2 new ones, 1 old one that was a known good one, they all failed, and the one that works perfectly is the big old accell yellow plastic one, that was the coil on the car when i bought it and drove it from Minnesota to Toronto in retarded hot conditions, and the car never went over 200-205 in insane heat. I also changed the ballast resistor, hot i was getting 8-9 volts at the coil, but changed it for piece of mind. The upgrades I've done to the cooling system (high flow stat, and water pump) really made a big difference. I can't believe i have 3 crappy coils....I can officially say the car is ok now.....thank GOD>.....
