Gas tank lock ring does not seal
#661368
04/05/10 03:20 AM
04/05/10 03:20 AM
Posts: 1,216 Fresno, CA
cudamank
Fresno, CA
I replace the stock 5/16" sending unit on my 70' cuda with a aftermarket 3/8's with the additional 5/16th port for a return line. I used the new lock ring and gasket that came with the sending unit, but now the tank will not seal properly.
I wanted to put the stock lock ring back on but of course when I check the box with the old pickup the lock ring is missing.
Has anyone else had problems with this? Could the rubber gasket be too thin?
Would love to more than 6 gallons of gas in the tank at a time.
Remember remember the 11th of September, of murder and a terriosts plot. I see no reason why this treachery should ever be forgot.
Re: Gas tank lock ring does not seal
[Re: cudamank]
#661369
04/05/10 08:54 AM
04/05/10 08:54 AM
RapidRobert
I would locate another oe lock ring and use a gasket the same thickness as the oe one (reuse your old one if it's OK & most are). The oe lock ring will still have plenty of tension as you tap it around and w no sealer used on that gasket reusing it is no problem, just wipe it off and make sure the tank surface in there is clean.
[Re: Andrewh]
#661373
04/05/10 11:35 AM
04/05/10 11:35 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
new O rings and also new tabs on gas tank for the locking ring are TOO WEAK, and the bend easily at the loking pressure ( BTDT on tank and new sender unit ). use the original lock ring, or over bend the new lock ring tabs
[Re: screamindriver]
#661375
04/05/10 06:51 PM
04/05/10 06:51 PM
Posts: 1,630 North Central Florida
eightlitermopar
I'm dealing with the same issue currently. I have doubled up on the gaskets. The inner lip of my tank is a little warped, so I will most likely put some sealer, rings, then the sending unit to clear it up. I wish I never would have taken the original out! Also, now when the tank is full, it never reads "full" for some reason, only 3/4 at best with the "new" sending unit. I have heard this is a common problem too. anyway, double up and see what happens. eight
Mopar or no car
[Re: eightlitermopar]
#661376
04/05/10 07:22 PM
04/05/10 07:22 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
eight
...and just what 'sealer' do you intend to use?
[Re: Pacnorthcuda]
#661377
04/05/10 07:33 PM
04/05/10 07:33 PM
eightlitermopar
eight
https://board.moparts.org/ubbthreads/show...e=0#Post5908086
There is a small part of the inner lip that is warped, a small amount of liquid metal to fill in the warped area (approx 1/4 of an inch of the lip), then go from there. I have the tank out now.
Nothing else I have done seems to seal it up. It's either this or drive around 1/4 of a tank at a time....or a new tank. I've replaced several of these and this is the first issue I have had, so I really don't know what to do either. eight
Mopar or no car
[Re: cudamank]
#661378
04/05/10 08:36 PM
04/05/10 08:36 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Watch out for the cheapo Chinese lock ring and gasket. Mine leaked like a stuck pig until a bought an OEM gasket and ring from the dealer.
[Re: torkrules]
#661379
04/05/10 09:08 PM
04/05/10 09:08 PM
RapidRobert
Any idea if this is a good one or not. the flat is .050" thick and the O ring is .075". $10 dollars to your door
[Re: RapidRobert]
#661380
04/06/10 12:14 AM
04/06/10 12:14 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I also had a repop tank on my 66 Charger and had to use two gaskets to get it to seal. On my Roadrunner, the repop ring was way too thick for a factory tank, and would not lock, I would up using a factory lock ring.. There are all kinds of variations out there..
[Re: RapidRobert]
#661381
04/06/10 06:56 AM
04/06/10 06:56 AM
torkrules
I'm neurotic
I'm neurotic
Hard to tell from pictures. Mine was too small in diameter and too thin. I have the actual tool and could see the ring moving up-down-sideways when trying to lock it. The OEM one fits with no movement and you can tell when it locks.
