Motor Plate Question? #660764
04/04/10 05:41 PM
04/04/10 05:41 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
I have a friend installing a B1 Headed 557 into an A Body Coupe. What is the best Motor Plate set up? A one piece deal or the more common Ears arrangement? Pics would be a great help.
Thanks in Advance.
AL....
Alan Jones
Re: Motor Plate Question? [Re: LA360] #660765
04/04/10 05:42 PM
04/04/10 05:42 PM
LA360 Offline OP
LA360  Offline OP
It's a 70 Valiant Hardtop if that helps.
AL....
Alan Jones
Re: Motor Plate Question? [Re: LA360] #660766
04/04/10 05:50 PM
04/04/10 05:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry no pics but I'm a firm believer in the single
one piece plate... the ears or 2 piece plate will flex
and pivot and alot of times loosen the bolts
Re: Motor Plate Question? [Re: MR_P_BODY] #660767
04/04/10 06:34 PM
04/04/10 06:34 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
And a lot neater look also.
Re: Motor Plate Question? [Re: '72CudaRacer] #660768
04/04/10 07:56 PM
04/04/10 07:56 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I can't remember who made it but I had 1 piece ears a while back. I do prefer a one piece design.
Re: Motor Plate Question? [Re: LA360] #660769
04/04/10 11:06 PM
04/04/10 11:06 PM
AndyF Offline
AndyF  Offline
Mancini sells a 3/8 thick motor plate for A body big block cars.
Re: Motor Plate Question? [Re: Bigcube] #660770
04/05/10 03:19 AM
04/05/10 03:19 AM
LA360 Offline OP
LA360  Offline OP
Thanks for the replies. Just wanted to make sure there wasn't some reason i couldn't run a 1 piece motor plate. I will measuring the car up and drawing the plate up in CAD. Then I will have the plate waterjet cut.
Thanks again, I will have some idea what it should look like.
AL.....
Alan Jones
Re: Motor Plate Question? [Re: LA360] #660771
04/05/10 03:27 AM
04/05/10 03:27 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
I would'nt bother to make one, not with our dollar the level it is,
Re: Motor Plate Question? [Re: SG duster] #660772
04/05/10 04:32 PM
04/05/10 04:32 PM
Mooresburg, Tn
Mooresburg, Tn
I made mine from a blank from S & W race cars. It had the cut out for timing chain cover, water pump holes and bolts. The cost was only slightly more than I could purchase a piece of 6061-T6 alum for locally.
Also don't forget that unless you are going to replace firewall and transmission tunnel, you need to offset the mount about 1.25" to passengers side(unless its a right side steer, then I don't know what to tell you).
Re: Motor Plate Question? [Re: LA360] #660773
04/05/10 06:06 PM
04/05/10 06:06 PM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
I bought mine from Chris Alston Chassisworks.. You could chop it down bigtime and lighten it up as much as you want... Around 100.00 if I remember correctly
Re: Motor Plate Question? [Re: '72CudaRacer] #660774
04/05/10 06:07 PM
04/05/10 06:07 PM
LA360 Offline OP
LA360  Offline OP
I will be looking at both options. I will be getting pricing on buying a S&W unit and the raw material. I have a full CNC shop to use, so making one would only cost me time.
AL....
Alan Jones
Re: Motor Plate Question? [Re: LA360] #660775
04/06/10 10:19 AM
04/06/10 10:19 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
When I bought my midplate from S&W, I had them lengthen the side by an inch. They did it for free.
You may want to find out the width of S&W's motor plate. If it is too short on one side for the offset you need, ask if they can make it wider for you. Then you could cut off what you don't need.
